    BMI160 shuttle board wiring problem/interrupts
    SaberKazemi1992
    Hello Bosch sensortec community
    I am using BMI160 shuttle board to have accel/gyroscope continuously. I am connecting:
    pins 1,2-> 3.3V
    pin3->GND
    pin4->MISO (master input/slave(BMI160) output)
    pin5->MOSI (master output/slave input)
    pin 6->SCLK (SPI clock)
    pin 7->CS (Chip select.)
    Are the above forms correct? and do I need any connections apart from them?
    Saber
    shellywang
    Occasional Contributor
    Re: BMI160 shuttle board wiring problem/interrupts
    The connection is correct if SPI bus communication is used.
