    BMI160 significant motion problem
    Marta
    Re: BMI160 significant motion problem
    thanks for your response! It works now!
    Marta
    j_marijan
    1. Yes. I am using version before commit(a23022cc3208fe367d886c65df2f025e80203037).
    2. Configuration sequence is:
    • sig_mot_proof -> 1=0.48s
    • sig_mot_skip -> 1=2.56s
    • sig_mot_threshold -> 10
    3. I would.
    4. I can do that, but every time I made a call of function bmi160_set_int_config with given parameters, BMI_OK result was returned every time.
    5. I read that in datasheet and I am aware of that fact. But, sometimes no matter what you do with device, interrupt is never triggered.
    Looking forward to your answer.
    j_marijan
    Any update on this topic?
    Josip
    femonsalvez
    Hi! I'm having problems with the first part:
    • Initialize sensor through bmi160_init
    I'm using a gy-bmi160 like this https://es.banggood.com/GY-BMI160-Module-6DOF-6-Axis-Angular-Velocity-Gyroscope-Gravity-Acceleration...
    I've tried to turn on a LED with the INT1 interrupt but I'm getting the 'Failure' message indicating the init went wrong. This is programmed into a ESP32 using SPI interface.
    Here's my code:
    #include "bmi160.h
    void setup() {
    int8_t rslt;
    Serial.begin(19200);
    pinMode(26,INPUT);
    pinMode(25,OUTPUT);
    struct bmi160_dev sensor;
    //Init Modo SPI
    sensor.id = 0;
    sensor.interface = BMI160_SPI_INTF;
    rslt = bmi160_init(&sensor);
    if(rslt==BMI160_OK){
        Serial.println("Success");
    }else{
         Serial.println("Failure");
    delay(1000);
    //Rango acc 2g, low power, 50HZ
    sensor.accel_cfg.odr = BMI160_ACCEL_ODR_50HZ;
    sensor.accel_cfg.power = BMI160_ACCEL_PMU_LOW_POWER;
    delay(5);
    /* Interrupcion INT1 */
    int_config.int_channel = BMI160_INT_CHANNEL_1;
    int_config.int_type = BMI160_ACC_ANY_MOTION_INT;// Choosing Any motion interrupt
    /* Select the Any-motion interrupt parameters */
    int_config.int_type_cfg.acc_any_motion_int.anymotion_en = BMI160_ENABLE;// 1- Enable the any-motion, 0- disable any-motion
    int_config.int_type_cfg.acc_any_motion_int.anymotion_x = BMI160_ENABLE;// Enabling x-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_y = BMI160_ENABLE;// Enabling y-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_z = BMI160_ENABLE;// Enabling z-axis for any motion interrupt
    int_config.int_type_cfg.acc_any_motion_int.anymotion_dur = 0;// any-motion duration
    int_config.int_type_cfg.acc_any_motion_int.anymotion_thr = 2;// (2-g range) -> (slope_thr) * 3.91 mg, (4-g range) -> (slope_thr) * 7.81 mg, (8-g range) ->(slope_thr) * 15.63 mg, (16-g range) -> (slope_thr) * 31.25 mg
    /* Set the Any-motion interrupt */
    bmi160_set_int_config(&int_config, &sensor); /* sensor is an instance of the structure bmi160_dev */
    void loop() {
    Serial.println(digitalRead(26));
    if(digitalRead(26)==1){
    digitalWrite(25,HIGH);
    Serial.println("Activated");
    delay(500);
    digitalWrite(25,LOW);
