I wanted to test the CRT feature on BMI270 using the Application Board 2.0, but didn't find any code in COINES for BMI270. Is there any plan on releasing the support for it on COINES? And, any suggestions on quickly evaluating it?
Thanks!
Currently COINES code not ready for BMI270,you can use DD2.0+APP2.0 running CRT. with following steps:
Hello jabezwinston,
BMI270 example code could be found from here: https://github.com/BoschSensortec/BMI270-Sensor-API
