    BMI270 Data
    akaun24
    BMI270 Data
    I'm trying to figure out how to convert data received from the sensor, for example acceleration to g values? So after I read registers, bit shift to get 16 bit value, I get around 4000 at rest. How do I convert that value to g?? Thank you.
    Vincent
    Re: BMI270 Data
    On datasheet page 13, the table have one item called "Sensitivity" for acceleration sensor,  you can refer to the value to convert the sensor read out value to g value.
    Take example as following:
    1.  you set the acceleration range is 8G
    2. from the table,  you get 4096 LSB/g
    2. you read vlaue is close to 4096, then you approximitaly get 1g output.  (read_out_value / 4096 *1g)
