Is there any documentation on how to manually load the configuration file into BMI270? So not using the "C" reference code but using something like Python to issue succesive write statements to Register 5E?
Hello Swingpro,
Here is my arduino code without API. ( This is not an official code, but test purpose.)
It's C code, but you can see how to write config file manually.
hi,
did you get an answer to your question?
or, did you find a solution?
this example allowed me to work with the device 🍾🍾🍾
