    BMI270 NO MOTION Interrupt on INT2
    I'm trying to configure the NO MOTION Interrupt on BMI270 connected to an STM32F072 over SPI.
    The interrupt is never generated and I have verified it both using an oscilloscope and monitoring the INT_STATUS_0 register (bit num. 5).
    This is the code I use to initialize the sensor:
    int8_t BMI270_DEVICE_Init() {
    	systemStatus.bmi270_init_count++;
    	int8_t rslt = BMI2_OK;
    	struct bmi2_sens_config configs[SENS_COUNT];
    	// Array to select sensors
    	uint8_t sens_list[SENS_COUNT] = {
    			BMI2_ACCEL,
    			BMI2_GYRO,
    			// BMI2_TEMP, // Since Gyro is enabled, temperature is automatically enabled [see datasheet]
    			BMI2_NO_MOTION,
    			BMI2_AUX
    	// ----> Set SPI interface params
    	bmi270_dev.read = bm_spi_read;
    	bmi270_dev.write = bm_spi_write;
    	bmi270_dev.delay_us = delayUs;
    	bmi270_dev.read_write_len = SPI_MAX_RW;
    	bmi270_dev.intf = BMI2_SPI_INTERFACE;
    	bmi270_dev.dev_id = 0;
    	bmi270_dev.dummy_byte = 1;
    	bmi270_dev.config_file_ptr = NULL; // Load the default `bmi270_config_file` hard coded in the driver
    	// <---- Set SPI interface params
    	// ----> Chip-ID read to test SPI communication
    	uint8_t chip_id;
    	rslt = bmi2_get_regs(BMI2_CHIP_ID_ADDR, &chip_id, 1, &bmi270_dev);
    	if (rslt != BMI2_OK || chip_id != BMI270_CHIP_ID) {
    		rslt = BMI2_E_COM_FAIL;
    		goto exit;
    	HAL_Delay(10);
    	// <---- Chip-ID read to test SPI communication
    	// ----> Initialize bmi270
    	rslt = bmi270_init(&bmi270_dev);
    	if (rslt != BMI2_OK)
    		goto exit;
    	// <---- Initialize bmi270
    	// ----> Enable Sensors
    	//rslt = bmi2_sensor_enable(sens_list, SENS_COUNT, &bmi270_dev);
    	rslt = bmi2_sensor_enable(sens_list, 2, &bmi270_dev);
    		goto exit;
    	// Accelerometer
    	configs[0].type = BMI2_ACCEL;
    	configs[0].cfg.acc.odr = BMI2_ACC_ODR_800HZ;
    	configs[0].cfg.acc.range = BMI2_ACC_RANGE_8G;
    	configs[0].cfg.acc.bwp = BMI2_ACC_OSR4_AVG1;
    	configs[0].cfg.acc.filter_perf = BMI2_PERF_OPT_MODE; // Filter for anti-aliasing
    	// Gyroscope
    	configs[1].type = BMI2_GYRO;
    	configs[1].cfg.gyr.odr  = BMI2_GYR_ODR_800HZ;
    	configs[1].cfg.gyr.range = BMI2_GYR_RANGE_1000 ;
    	configs[1].cfg.gyr.bwp =  BMI2_GYR_NORMAL_MODE;
    	configs[1].cfg.gyr.filter_perf = BMI2_PERF_OPT_MODE ; // Filter for anti-aliasing
    	configs[1].cfg.gyr.noise_perf = BMI2_PERF_OPT_MODE;
    	// No Motion detection
    	configs[2].type = BMI2_NO_MOTION;
    	configs[2].cfg.no_motion.select_x = BMI2_ENABLE;
    	configs[2].cfg.no_motion.select_y = BMI2_ENABLE;
    	configs[2].cfg.no_motion.select_z = BMI2_ENABLE;
    	configs[2].cfg.no_motion.out_conf = 0x06; // INT_STATUS_0 and INT2_MAP_FEAT  bit #5
    	configs[2].cfg.no_motion.duration = 5;
    	configs[2].cfg.no_motion.threshold = 144;
    	// Magnetometer
    	configs[3].type = BMI2_AUX;
    	configs[3].cfg.aux.aux_en = BMI2_ENABLE;
    	configs[3].cfg.aux.manual_en = BMI2_TRUE;
    	configs[3].cfg.aux.i2c_device_addr = 0x10; // I2C address of BMM150
    	configs[3].cfg.aux.read_addr = 0x40;	// Address of the first read address
    	configs[3].cfg.aux.man_rd_burst = 50;	// Total number of registers to be read for manual burst (0x40 to 0x71)
    	configs[3].cfg.aux.offset = 2;			// Offset for auto burst read
    	configs[3].cfg.aux.aux_rd_burst = 8;	// Size of auto burst read
    	configs[3].cfg.aux.fcu_write_en = BMI2_ENABLE;
    	configs[3].cfg.aux.odr = 1;
    	// Set the configurations
    	rslt = bmi2_set_sensor_config(configs, SENS_COUNT, &bmi270_dev);
    		goto exit;
    	// <---- Enable Sensors
    	//	// TODO Configure BMM150 after BMI270 using bmi2_write_aux_man_mode
    	// ----> Interrupt PINs configuration
    	struct bmi2_int_pin_config int_pin_cfg;
    	int_pin_cfg.pin_type = BMI2_INT1;
    	int_pin_cfg.int_latch = BMI2_INT_NON_LATCH;
    	for(uint8_t i=0; i<BMI2_INT_PIN_MAX_NUM; i++ ) {
    		int_pin_cfg.pin_cfg[i].output_en = BMI2_INT_OUTPUT_ENABLE; 	// Output enabled
    		int_pin_cfg.pin_cfg[i].od = BMI2_INT_PUSH_PULL;				// OpenDrain disabled
    		int_pin_cfg.pin_cfg[i].lvl = BMI2_INT_ACTIVE_LOW;			// Signal Low Active
    		int_pin_cfg.pin_cfg[i].input_en = BMI2_INT_INPUT_DISABLE;	// Input Disabled
    	rslt =  bmi2_set_int_pin_config( &int_pin_cfg, &bmi270_dev);
    		goto exit;
    	// <---- Interrupt PINs configuration
    	// ----> Map data interrupt
    	rslt = bmi2_map_data_int( BMI2_DRDY_INT, BMI2_INT1, &bmi270_dev);
    		goto exit;
    	// <---- Map data interrupt
    	// ----> Map features interrupts
    	struct bmi2_sens_int_config feat_int;
    	feat_int.type = BMI2_NO_MOTION;
    	feat_int.hw_int_pin = BMI2_INT2;
    	rslt = bmi2_map_feat_int(&feat_int, 1, &bmi270_dev);
    		goto exit;
    	// <---- Map features interrupts
    	exit:
    	if( rslt == BMI2_OK ) {
    		systemStatus.bmi270_initialized = 1;
    	} else {
    		systemStatus.bmi270_initialized = 0;
    	return rslt;
    }</bmi2_int_pin_max_num;>
    Any advice?
    Thank you
    Walter
    Re: BMI270 NO MOTION Interrupt on INT2
    I tested many configurations, but I continue to not being able to get the NO_MOTION interrupt working.
    I also moved the DATA_READY interrupt to INT2 to verify that it is correctly configured and it's ok, so it's a configuration problem that I cannot figure out.
    Any advise?
