    BMI270 SPI Init error
    JulianGra
    I am trying to initalize the BMI270 with CY8C4024AXI with the SPI interface. I get the right Chip_ID and i can write the config file from the API but i always get the error code 0xF7 from the internal status register (0x21).  This is a compat_error but i did not find much information about this error.
    I have also checket the first read and write before the config file and that are ok ( i compared it with a initialization sequence that i found in this forum).
    I have attached my code.
    Julian
    4 REPLIES 4
    Hi JulianGra,
    For you code, you can read 0x21 register after sensor initialization.
    In bmi270_init() function, it will call bmi2_soft_reset() to perform soft-reset to bring all register values to their default values.
    Hi BSTRobin,
    Sry i made a mistake.  I am getting 0x00 (not_init) back of the internal register after writing the config file.
    Hello
    I have tried to increase the time after writing the config file and i have tried to ask request the internal status again. But it did not helped.
    Did anyone has another solution or a example code for a cypress controller.
    Julian
    Hi JulianGra,
    See it from you previous code, you are using BMI270 base version software. I uploaded example code on STM32 for your reference.
    BMI270 (base)
    • Any motion, No motion, Significant motion detectors
    • Wrist worn Step counter and Step detector (Pedometer)
    • Activity change recognition
      • Still
      • Walking
      • Running
    • Wrist gestures
      • Push arm down
      • Pivot up
      • Wrist shake jiggle
      • Flick in
      • Flick out
    • Wrist wear wake up
    BMI270 Context
    • Step counter and Step detector (Pedometer)
      • Still
      • Walking
      • Running
    BMI270 Legacy
    • Orientation detector (Advanced Potrait-Landscape)
    • High-G, Low-G (Freefall) detector
    • Flat detector
    • Tap detection (Single, Double, Triple taps)
    • Smartphone Step counter and Step detector (Pedometer)
      • Still
      • Walking
      • Running
    BMI270 Maximum FIFO
    • Supports a 6kB FIFO
