09-27-2022 02:38 PM
Hello.
https://github.com/BoschSensortec/BMI270-Sensor-API/tree/master/bmi270_examples/sensor_data I tried to adapt the example to NRF52832 microcontroller. but I didn't get any response from the sensor.
I'm sure the links are correct. I added my source code.
Please help me.
NOT: interface functions are available in the common.c file. and the sensor initialization main code is available in the main.c file. All source codes are also available in spi3 branch file.
09-28-2022 12:42 AM
Hi Mess,
Did you check rslt value for every function in sensor data.c example code?
I guess you should get any error msg from it.
Or, could you check it where did you stall it?
09-28-2022 08:21 AM
