03-22-2023 08:50 AM
Hi, BOSCH
When you turn your hand with your watch on
I set the screen to work using Wrist wear wake up and Wrist gesture featrue.
We are using Wrist wear wake up and Wrist gesture featrue, and each setting value is as follows.
1. Wrist wear wakeup
① min_angle_focus = 1024;
② min_angle_nonfocus = 1856;
③ max_tilt_lr = 1024;
④ max_tilt_ll = 700;
⑤ max_tilt_pd = 179;
⑥ max_tilt_pu = 1978;
2. Wrist gesture
① wearable_arm = BMI2_ARM_LEFT;
② max_duration = 150;
When set to the above value
The screen lights up, but it comes in a little slower. I'm slow to react
How can I set it to speed up the lighting on the screen?
03-28-2023 07:19 AM
Hi, BSTRobin
I can't see any improvement even though I configured the default parameter at 50Hz.
Is there any parameter or solution that can be improved?
04-04-2023 06:40 AM
Hi, BOSCH
Please respond to the above question, 50Hz,
Regarding Double Tap
The exact cause will have to be identified, but the following symptoms often occur.
- I don't know why, but it seems that certain settings have to be turned off and then put back on to reflect it.
- There seems to be no problem in use, but there will be confusion when uploading without turning off the power during development.
Do you have any relevant data or solutions for this?
05-05-2023 08:26 AM
Hi mgchoi,
Are you using another config file as you ask question about BMI270 TAP?
If you are using BMI270 Legacy config file and sensor API, you could refer tap example code on github https://github.com/boschsensortec/BMI270-Sensor-API/tree/master/bmi270_legacy_examples/tap, and ensure ACC ODR is at least 200 Hz.
