    BMI270 & Arduino
    jankettner
    BMI270 & Arduino
    Hello MEMS-fans,
    Ive got some issues with the arduino sketch
    https://gist.github.com/BoschSensortec/53a27010ff5af5350b3641ee46d34762
    and the new API
    https://github.com/BoschSensortec/BMI270-Sensor-API
    I think both are incompatible, i m getting a lot of compiler errors.
    Does anybody have the project at a running state and can help me  ?
    Regards Jan
    Re: BMI270 & Arduino
    Hello Janket,
    Here is bmi270 example code for arduino DUE.
    Please let me know if you have further questions.
    vamshi
    Hi @Minhwan,
    Thank you for providing bmi270 example code for Arduino. I tried with that code using ESP32-C3 Dev Kit. I have used both INT1 and INT2 Pins for Data ready Interrupt. Usually when data is ready, sensor needs to generate interrupt right ?
    But interrupt is not generating with that code. Can you please go through the below connection and code. Can you please tell me, what might be the issue ?
    Any help would be very thankful.
    Tags (2)
    In your attached schmetic, there is no connection between BMI270 and arduino for interrupt pins. Should be hardware wired for pins.
