    BMI270 gyro
    joma
    BMI270 gyro
    In Bosch Sensortec | BMI270 Data sheet:
    page 110 - Register (0x42) GYR_CONF  says that odr_6k4 is reserved.
    page 2 says: Output data rates (ODR): 25 Hz ... 6.4 kHz (gyroscope) and 0.78 Hz ... 1.6 kHz (accelerometer)
    How can I set odr_6k4 for gyro ?
    If gyro ODR is 3k2 I'm getting about 60 interrupts per sec (with my watermark settings). If I chane ODR to 6k4 I'm getting about 24 interrupts per sec.
    FAE_CA1
    Re: BMI270 gyro
    If you set register 0x45 bit-3 gyr_fifo_filt_data to 0, then gyro unfiltered data will be filled in FIFO at 6.4KHz rate.
    kpoon12
    Re: BMI270 gyro
    I set register 0x45 bit-3 gyr_fifo_filt_data to 0 but gyro data ready interrupt is still 200Hz and not 6.4KHz rate.
    Do I need to set other register?
    Minhwan
    Re: BMI270 gyro
    Hello kpoon12,
    Technically, you need to clear 4th bit in 0x45 register.
    But, this is not that all for your fifo setting.
    Therefore, I don't recommend to develop BMI270 w/o API. (If now, you are using our BMI270 API, that's great!)
    Please BMI270 API as below URL.
    https://github.com/BoschSensortec/BMI270-Sensor-API
    And here is the my gyro fifo 6.4k ODR example code as attaced file.
