    BMI270 init with I2C
    Eason
    Hallo
    I try to use this programm.When I use SPI, BMI runs normally.But in the process of using IIC, there was a problem. In the setup program, the value of rslt is not equal to the BMI_OK value.This means this connection was not successful.
    09:58:59.151 rslt-> -2
    09:58:59.151 BMI_OK-> 0
    This is my setup program, what went wrong. Thank you very much
    void setup() {
      /* Variable to define result */
      int8_t rslt;
      pinMode(BMI270_CS, OUTPUT);
      pinMode(interruptPin, INPUT_PULLUP);
      digitalWrite(BMI270_CS, HIGH);
      //  Wire.setModule(0);
      Serial.begin(115200);
      i2c_bus = 0x68;
     // spi_bus = BMI270_CS;
      /* To initialize the hal function */
      //SPI.begin();
      Wire.begin();
      bmi2.intf_ptr = &i2c_bus;
      bmi2.intf = BMI2_I2C_INTF;
      bmi2.read = bmi2xy_hal_i2c_bus_read;
      bmi2.write = bmi2xy_hal_i2c_bus_write;
      bmi2.read_write_len = 32;
      bmi2.delay_us = bmi2xy_hal_delay_usec;
      /* Config file pointer should be assigned to NULL, so that default file address is assigned in bmi270_init */
      bmi2.config_file_ptr = NULL;
      /* Initialize bmi270 */
      rslt = bmi270_init(&bmi2);
      Serial.println("bmi270_init done");
      rslt = bmi2_accel_gyro_set_config(&bmi2);
      Serial.println(rslt);
      Serial.println(BMI2_OK);
      if (rslt == BMI2_OK)
        Serial.println("Accel data Ready : X Y Z ");
        Serial.println("Gyro data Ready : X Y Z ");
      delay(250);
      // Interrupt PINs configuration
      struct bmi2_int_pin_config data_int_cfg;
      data_int_cfg.pin_type = BMI2_INT1;
      data_int_cfg.int_latch = BMI2_INT_NON_LATCH;
      data_int_cfg.pin_cfg[0].output_en = BMI2_INT_OUTPUT_ENABLE; // Output enabled
      data_int_cfg.pin_cfg[0].od = BMI2_INT_PUSH_PULL;      // OpenDrain disabled
      data_int_cfg.pin_cfg[0].lvl = BMI2_INT_ACTIVE_LOW;      // Signal Low Active
      data_int_cfg.pin_cfg[0].input_en = BMI2_INT_INPUT_DISABLE;  // Input Disabled
      rslt =  bmi2_set_int_pin_config( &data_int_cfg, &bmi2);
      pinMode(interruptPin, INPUT);
      attachInterrupt(digitalPinToInterrupt(interruptPin), RawDataHandler, FALLING);
    Hello Eason,
    Which line you got -2 return value?
    Suggest you could capture I2C waveform by logic analyzer, and compare the difference between SW code and I2C waveform.
    From this line "Serial.println(rslt);" I get -2
    void setup() {
      int8_t rslt;
      i2c_bus = 0x68;
      //SPI.begin();
      Wire.begin();
      bmi2.read_write_len = 16;
      delay(250);
    Hallo
    This is my program, which part of the program has a problem that prevents the BMI270 from connecting with Arduino Due
    Hello Eason,
    Return value -2 indicated communication fail error. Firstly you should check I2C communication works well.
    This is I2C read/write function on STM32 platform for your reference.
    int8_t SensorAPI_I2Cx_Read(uint8_t slave_address7, uint8_t subaddress, uint8_t *pBuffer, uint16_t ReadNumbr)
    uint16_t DevAddress = slave_address7 << 1;
    // send register address
    HAL_I2C_Master_Transmit(&I2C_HANDLE, DevAddress, &subaddress, 1, BUS_TIMEOUT);
    HAL_I2C_Master_Receive(&I2C_HANDLE, DevAddress, pBuffer, ReadNumbr, BUS_TIMEOUT);
    return 0;
    int8_t SensorAPI_I2Cx_Write(uint8_t slave_address7, uint8_t subaddress, uint8_t *pBuffer, uint16_t WriteNumbr)
    GTXBuffer[0] = subaddress;
    memcpy(&GTXBuffer[1], pBuffer, WriteNumbr);
    HAL_I2C_Master_Transmit(&I2C_HANDLE, DevAddress, GTXBuffer, WriteNumbr+1, BUS_TIMEOUT);
    return 0;
