    BMI270 initialization issue with PIC32MZ204BEFH064
    yosibuc
    I'm working with the BMI270 with PIC32MZ204BEFH064 over SPI. I'm using the Gihub driver and I have problems with the initialization of the devide.
    Debugging the code I noticed that the initialization fails when reading for the config files back after writing.
    The "INTERNAL_STATUS (0x21)" value is 0x02 = init_err
    The error I get is always `BMI2_E_CONFIG_LOAD`.
    Following my initialization code:
    #define SPI_BUFF_SZ (8+1)
    void user_delay_us(uint32_t period_us, void *intf_ptr)
    /* Wait for a period amount of microseconds. */
    DelayUs((unsigned long int)period_us);
    * @brief This function is for writing the sensor's registers through SPI bus.
    int8_t user_spi_reg_write(uint8_t reg_addr, const uint8_t *reg_data, uint32_t length, void *intf_ptr)
    /* Write to registers using SPI. Return 0 for a successful execution. */
    int i;
    uint8_t tmp_TX_buf[SPI_BUFF_SZ];
    // if( length > (SPI_BUFF_SZ-1) )
    // return -1; //YOSSI TODO- implement Error_Handler();
    tmp_TX_buf[0] = k_SPI_WRITE_REG_VAL | reg_addr;
    memcpy(tmp_TX_buf + 1, reg_data, length);
    LATEbits.LATE4 = 0; //CS BMI270 = 0;
    TP4 = 0;
    //FREEing THE SPI BUF
    while (SPI2STATbits.SPIRBF)
    tmp_TX_buf[0] = SPI2BUF;
    SPI2BUF = tmp_TX_buf[0] & 0xFF;
    while(!SPI2STATbits.SPIRBF);
    for(i=0; i<length; i++)
    SPI2BUF = tmp_TX_buf[1+i] & 0xFF;
    tmp_TX_buf[1+i] = SPI2BUF;
    LATEbits.LATE4 = 1; //CS BMI270 = 1;
    TP4 = 1;
    return 0;
    * @brief This function is for reading the sensor's registers through SPI bus.
    int8_t user_spi_reg_read(uint8_t reg_addr, uint8_t *reg_data, uint32_t length, void *intf_ptr)
    /* Read from registers using SPI. Return 0 for a successful execution. */
    int i;
    uint8_t tmp_TX_buf[10];//,CRM_RX_buf[100];
    TP4 = 0;
    tmp_TX_buf[0] = k_SPI_READ_REG_VAL | reg_addr;
    reg_data[0] = SPI2BUF;
    reg_data[0] = SPI2BUF; //
    for(i=0;i<length;i++)
    SPI2BUF = tmp_TX_buf[i] & 0xFF;
    reg_data[i] = SPI2BUF; //
    //BMI270 = 1;
    LATEbits.LATE4 = 1;
    TP4 = 1;
    return 0;
    int8_t bmi2_interface_selection(struct bmi2_dev *dev)
    int8_t rslt = BMI2_OK;
    if (dev != NULL)
    /* Select the interface for execution
    * For I2C : BMI2_I2C_INTF
    * For SPI : BMI2_SPI_INTF
    dev->intf = BMI2_SPI_INTF;
    6 REPLIES 6
    FYI..... but still thanks pointing me to the issue.
    It is good, your program runs normally.
