Hi everyone,
on the BMI270 datasheet there is a mismatch about the scale factor to be applied to the raw timestamp to convert it in usec.
Two values are reported: 39.0625us and 39.06125 us
Which is the correct one?
On the same topic the datasheet of the BMI160 (we use it in older devices) report "around 39 usec". Can we use the same value of BMI270?
Thank you
Walter
