Hello forum can you tell me how to intagrate API for stm32 spi please Thank You
Hi Noro,
You could refer attached example code runs on STM32F4.
this is my function
void spiWriteRegister16(uint8_t reg, uint16_t value, GPIO_TypeDef *port, uint16_t cs) {
uint8_t data[3];
data[0] = reg;
data[1] = (uint8_t)(value >> 8); // transmit MSB first
data[2] = (uint8_t)(value & 0xFF); // transmit LSB second
HAL_GPIO_WritePin(port, cs, GPIO_PIN_RESET); // make chip select low to enable transmission
HAL_SPI_Transmit(&hspi1, data, 3, 10); // write data to register
HAL_GPIO_WritePin(port, cs, GPIO_PIN_SET); // make chip select high at the end of transmission
uint16_t spiReadRegister16(uint8_t reg, GPIO_TypeDef *port, uint16_t cs) {
uint8_t address = reg | 0x80; // read operation with auto-increment
uint8_t data[4] = {0};
HAL_SPI_Transmit(&hspi1, &address, 1, 1); // send address
HAL_SPI_Receive(&hspi1, data, 4, 1); // read the data from device
return ((uint16_t)data[2] << 😎 | data[3];
void readAllAccel() {
uint8_t address = 0x03;
uint8_t txBuf[1] = {address | 0x80}; // read operation, MSB is 1
uint8_t rxBuf[20] = {0}; // initialize to 0
HAL_GPIO_WritePin(GPIOA, SPI_CS_Pin, GPIO_PIN_RESET); // make chip select low to enable transmission
HAL_SPI_TransmitReceive(&hspi1, txBuf, rxBuf, 1, 10); // send address and receive data
HAL_SPI_TransmitReceive(&hspi1, &txBuf[1], &rxBuf[1], 19, 10); // receive the rest of the data
HAL_GPIO_WritePin(GPIOA, SPI_CS_Pin, GPIO_PIN_SET); // make chip select high at the end of transmission
//Offset = 2 because the 2 first bytes are dummy (useless)
int offset = 2;
x = ((rxBuf[offset + 1] << 8 | (uint16_t)rxBuf[offset + 0])); //0x03
y = ((rxBuf[offset + 3] << 8 | (uint16_t)rxBuf[offset + 2])); //0x04
z = ((rxBuf[offset + 5] << 8 | (uint16_t)rxBuf[offset + 4])); //0x05
gyr_x = (rxBuf[offset + 7] << 8 | (uint16_t)rxBuf[offset + 6]); //0x06
gyr_y = (rxBuf[offset + 9] << 8 | (uint16_t)rxBuf[offset + 8]); //0x07
gyr_z = (rxBuf[offset + 11] << 8 | (uint16_t)rxBuf[offset + 10]); //0x08
temperature = (rxBuf[offset + 13] << 8 | (uint16_t)rxBuf[offset + 12]); //0x09
void softReset(){
spiWriteRegister16(CMD, 0xDEAF,GPIOA,SPI_CS_Pin);
HAL_Delay(50);
#define ACC_CONF 0x20 //Page 91
#define GYR_CONF 0x21 //Page 93
#define CMD 0x7E //Page 65
#define GRAVITY_EARTH (9.80665f)
uint16_t temperature = 0;
int16_t x, y, z;
int16_t gyr_x, gyr_y, gyr_z;
init device
softReset();
spiWriteRegister16(ACC_CONF,0x4027,GPIOA,SPI_CS_Pin);
spiWriteRegister16(GYR_CONF,0x760B,GPIOA,SPI_CS_Pin);
please see if this is correct Thanks
Hi Noro,
You SPI write, read function only supports data access that is 2 bytes long.
BMI323 sensor API https://github.com/boschsensortec/BMI323-Sensor-API has implemented the function how to access sensor.
You only need the appropriate read, write, delay_us interface, then you can access the sensor normally.
Previous attached example code has demostrated how to use SPI to access BMI323 on STM32 for your reference.
I connected as in your code sent, I don’t see anything after the ID
