12-13-2022 07:45 PM
For weeks now, I've been trying to get the API to work, but between the confusing and severlely lacking API and almost non-existant documentation referencing the API in the datasheet, I am totally lost.
I've gotten to the point where I can read/write the sensor registers without issue through custom I2C read/write functions, but I absolutely cannot read/write through the API functions. They all return `0`, and seem to pass the error checks, however, they still do NOT actually read/write the registers.
What am I missing here? Even when I run the provided mag_drdy_interrupt.c example, I get `-32,768` from the sensor axes... yet, I can get normal values when I use my own read functions.
Even when I set a setting through the API functions, it doesn't appear to actually be setting that register to what I'm telling it to. I have no idea what is going on, and am at my wits end trying to troubleshoot Bosch sensors. Any help is greatly appreciated!
#include <stdio.h>
#include "boards.h"
#include "app_util_platform.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrfx_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#include "nrf_log_default_backends.h"
#include "bmm150.h"
#include "bmm150_common.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
void twi_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = NRF_GPIO_PIN_MAP(0, 27),
.sda = NRF_GPIO_PIN_MAP(0, 26),
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, NULL, NULL);
//printf("Error Code init\t%d\n", err_code);
nrf_drv_twi_enable(&m_twi);
// MAIN
int main(void)
struct bmm150_dev dev;
struct bmm150_settings mySettings;
struct bmm150_mag_data mag_data;
int a1, a2, b, c, d, e, f, g, h, i;
dev.intf = BMM150_I2C_INTF;
dev.read = bmm150_user_i2c_reg_read;
dev.write = bmm150_user_i2c_reg_write;
dev.delay_us = 3;
printf("Breaker 1\n");
twi_init();
uint8_t tempValx[8] = {0};
bmm150_get_regs(0x4b, tempValx, 1, &dev);
for(int a = 0; a < sizeof(tempValx); a++){
printf("getRegs %d\t%d\n", a, tempValx[a]);
printf("Breaker 2\n");
nrf_delay_ms(2500);
a1 = bmm150_interface_selection(&dev);
printf("rslt A1:\t%d\n", a1);
a2 = bmm150_init(&dev);
printf("rslt A2:\t%d\n", a2);
mySettings.pwr_mode = BMM150_POWERMODE_NORMAL;
b = bmm150_set_op_mode(&mySettings, &dev);
printf("rslt B:\t%d\n", b);
mySettings.preset_mode = BMM150_PRESETMODE_REGULAR;
c = bmm150_set_presetmode(&mySettings, &dev);
printf("rslt C:\t%d\n", c);
mySettings.int_settings.drdy_pin_en = 0x01;
d = bmm150_set_sensor_settings(BMM150_SEL_DRDY_PIN_EN, &mySettings, &dev);
printf("rslt D:\t%d\n", d);
e = bmm150_get_interrupt_status(&dev);
printf("rslt E:\t%d\n", e);
printf("Dev->int_status:\t%d\n", dev.int_status);
printf("BMM150_INT_ASSRTED_DRDY:\t%d\n", BMM150_INT_ASSERTED_DRDY);
// Startup Config Functions
printf("Mag X:\t%d\n", mag_data.x);
printf("Mag Y:\t%d\n", mag_data.y);
printf("Mag Z:\t%d\n", mag_data.z);
while(true){
uint8_t dsa = bmm150_read_mag_data(&mag_data, &dev);
printf("bmm150_read_mag_data:\t%d\n", dsa);
printf("Interrupt Status\t%d\n", dev.int_status);
nrf_delay_ms(100);
12-20-2022 10:28 AM
