Hi
I am trying to compare the raw x,y,z values of BMI160+BMM150 with BMI270+BMM150
By keeping both the PCB's in same position I took the values and they are as below
BMI160+BMM150
Accel x y z -1996 76 451
Gyro x y z 8 -1 3
Mag 8 bytes (values from register in manual mode)113 0 233 0 71 0 41 106
MAG x y z 14 29 35
BMI270+BMM150
Accel x y z -1999 -75 552
GYRO x y z -2319 33 -2267
Mag 8 bytes (values from data register in manual mode) 57 13 65 12 173 0 188 100
MAG x y z 423 392 86
I am not understanding why there is a drastic change in both the values when i maintained the same configuration and same positon.
Can someone help me on this.?
If you are able to get the same values in both the setups, can you share your coonfiguration.
Thanks in advance
Hello Santhosh_N,
Could we know some information from you.
1. What is your product application?
2. What was the software you used?
3. Did you only tested on PCB, not assembled to structure as a whole machine?
4. On your PCB, what other general circuits are there?
Hi
1. We use rawdata of accel, gyro and mag to calculate body motion.
2. I took the example code from https://github.com/BoschSensortec/BMM150-Sensor-API and integrated into my application.
3,4. Tested this on our PCB, we are having a working BMI160+BMM150 board on which we replaced BMI160 to BMI270 as both have the same functionality to read rawdata. Yes there are other components on the PCB but they shouldn't effect the sensors because they are woking well on BMI160.
But now we are not getting the similar values for mag which is aux in BMI270+BMM150.
Do we get similar rawdata of x,y,z when we compare BMI160+BMM150 with BMI270+BMM150.?
This is the config of aux I am using
/* Configurations for aux. */
config[AUX].cfg.aux.odr = BMI2_AUX_ODR_100HZ;
config[AUX].cfg.aux.aux_en = BMI2_ENABLE;
config[AUX].cfg.aux.i2c_device_addr = BMM150_DEFAULT_I2C_ADDRESS;
config[AUX].cfg.aux.manual_en = BMI2_ENABLE;
config[AUX].cfg.aux.fcu_write_en = BMI2_ENABLE;
config[AUX].cfg.aux.man_rd_burst = BMI2_AUX_READ_LEN_3;
/* Set the power mode to normal mode. */
settings.pwr_mode = BMM150_POWERMODE_NORMAL;
rslt = bmm150_set_op_mode(&settings, &bmm150_dev);
@BSTRobin
Any update on this
Hello Santhosh_N,
I built HW & SW with BMI160+BMM150, BMI270+BMM150 these days. By keeping both the PCB's in same position I took the values and they are as below. From test result, it didn't have big difference for MAG data value.
BMI270+BMM150
BMI160+BMM150
int8_t Open_BMI270_AUX(struct bmi2_dev *dev)
int8_t rslt = BMI2_OK;
uint8_t regdata;
uint8_t sensor_list = BMI2_AUX;
/* Sensor configuration structure */
struct bmi2_sens_config config = { 0 };
config.type = sensor_list;
bmm150dev.dev_id = BMM150_DEFAULT_I2C_ADDRESS;
bmm150dev.intf = BMM150_I2C_INTF;
bmm150dev.read = (bmm150_com_fptr_t)user_aux_read;
bmm150dev.write = (bmm150_com_fptr_t)user_aux_write;
bmm150dev.delay_ms = (bmm150_delay_fptr_t)HAL_Delay;
/* Pull up resistor 2k is set to the trim regiter */
regdata = 0x03;//PUP_RES_2K
rslt = bmi2_set_regs(BMI2_I2C_PRIM_ADDR, ®data, 1, dev);
print_bmi270_rslt(rslt);
/* Enable the selected sensors */
rslt = bmi2_sensor_enable(&sensor_list, 1, dev);
PDEBUG("bmi2_sensor_enable BMI2_AUX\r\n");
/* Get default configurations for the type of feature selected. */
rslt = bmi2_get_sensor_config(&config, 1, dev);
config.cfg.aux.odr = BMI2_AUX_ODR_25HZ;
config.cfg.aux.aux_en = BMI2_ENABLE;
config.cfg.aux.i2c_device_addr = BMM150_DEFAULT_I2C_ADDRESS;
config.cfg.aux.manual_en = BMI2_ENABLE;
config.cfg.aux.fcu_write_en = BMI2_ENABLE;
config.cfg.aux.man_rd_burst = BMI2_AUX_READ_LEN_3;
config.cfg.aux.read_addr = BMM150_DATA_X_LSB;
/* Set new configurations for accel, gyro and aux. */
rslt = bmi2_set_sensor_config(&config, 1, dev);
/* Initialize bmm150. */
rslt = bmm150_init(&bmm150dev);
bmm150dev.settings.pwr_mode = BMM150_NORMAL_MODE;
rslt = bmm150_set_op_mode(&bmm150dev);
if(rslt != BMM150_OK)
PDEBUG("Set BMM150_FORCED_MODE failed, rslt=%d\r\n", rslt);
/*bmm150dev.settings.preset_mode = BMM150_PRESETMODE_LOWPOWER;
rslt = bmm150_set_presetmode(&bmm150dev);
/* Disable manual mode so that the data mode is enabled. */
config.cfg.aux.manual_en = BMI2_DISABLE;
/* Set the aux configurations. */
return rslt;
