    BMM150 Trim Values & Z repetitions
    Vinod
    I am working with Arduino Nano BLE33_Sense Rev. 2 MCU.  This MCU has built-in sensors, BMI270, BMM150, etc.  I am writing app for BMM150 to determine heading.  I have extracted the trim data from the trim registers.  These data are partially in agreement with the trim data shown in one of your data sheet, shown below:
                                                 BOSCH Data                      Data from
        Arduino MCU
    dig_X1                         0                                                  0
    dig_Y1                          0                                                  0
    dig_X2                         26                                               25                         different
    dig_Y2                          26                                               25                         different
    dig_xy1                        29                                               29
    dig_xy2                        -3                                                -3
    dig_z1                          22752                                        21463                  different
    dig_z2                          737                                             770                       different
    dig_z3                          -1035                                         0                            different
    dig_z4                          0                                                  0
    dig_xyz1                      6753                                           7019                     different
    I am not sure what to make of the difference.  Please help me if the difference is due to Arduino with built-in sensors or I am making some mistake in extracting the data.  By the way, one the app supplied by Arduino for BMM150 also reproduced the same data as mine.
    A second question I have is regarding preset values for REPZ repetitions (register 0x52).  According to the definition input value should be 14 (15 -1) for BMM150_REPZ_REGULAR preset.  Please help me, if my interpretation is flawed. What is the significance of the repetitions?
    Thanks, Vinod
    Hi Vinod,
    You could refer BMM150 official sensor API and example code to get sensor data, by call bmm150_read_mag_data() to get compensated x, y, z mag data.
    https://github.com/boschsensortec/BMM150-Sensor-API/tree/master/examples/generic
    In BMM150 sensor API, z_rep was set according different preset mode.
    * @brief This API is used to set the preset mode of the sensor.
    int8_t bmm150_set_presetmode(struct bmm150_settings *settings, struct bmm150_dev *dev)
    int8_t rslt;
    uint8_t preset_mode;
    /* Check for null pointer in the device structure */
    rslt = null_ptr_check(dev);
    /* Proceed if null check is fine */
    if (rslt == BMM150_OK)
    preset_mode = settings->preset_mode;
    switch (preset_mode)
    case BMM150_PRESETMODE_LOWPOWER:
    /* Set the data rate x,y,z repetition
    * for Low Power mode
    settings->data_rate = BMM150_DATA_RATE_10HZ;
    settings->xy_rep = BMM150_REPXY_LOWPOWER;
    settings->z_rep = BMM150_REPZ_LOWPOWER;
    rslt = set_odr_xyz_rep(settings, dev);
    break;
    case BMM150_PRESETMODE_REGULAR:
    * for Regular mode
    settings->xy_rep = BMM150_REPXY_REGULAR;
    settings->z_rep = BMM150_REPZ_REGULAR;
    break;
    case BMM150_PRESETMODE_HIGHACCURACY:
    * for High Accuracy mode *
    settings->data_rate = BMM150_DATA_RATE_20HZ;
    settings->xy_rep = BMM150_REPXY_HIGHACCURACY;
    settings->z_rep = BMM150_REPZ_HIGHACCURACY;
    break;
    case BMM150_PRESETMODE_ENHANCED:
    * for Enhanced Accuracy mode
    settings->xy_rep = BMM150_REPXY_ENHANCED;
    settings->z_rep = BMM150_REPZ_ENHANCED;
    break;
    default:
    rslt = BMM150_E_INVALID_CONFIG;
    break;
    return rslt;
