    BMM150 Z value not correct
    Myzhar
    Re: BMM150 Z value not correct
    We finally found the problem using X-Ray: a simply short circuit under the sensor due to a wrong way of placing the soldering paste.
    Now the sensors seems to work correctly, even if the Z axis is showing a very low working range, but I expect to solve this with hard and soft iron calibration.
    Myzhar
    Hi o_o,
    the Z2 value to zero is a possible value, but in the "compensate_z" function it is checked and generates a `BMM150_OVERFLOW_OUTPUT` error.
    This is the function I'm referring to:
     * @brief This internal API is used to obtain the compensated
     * magnetometer Z axis data(micro-tesla) in int16_t.
    int16_t compensate_z(int16_t mag_data_z, uint16_t data_rhall, const struct bmm150_dev *dev)
    	int32_t retval;
    	int16_t process_comp_z0;
    	int32_t process_comp_z1;
    	int32_t process_comp_z2;
    	int32_t process_comp_z3;
    	int16_t process_comp_z4;
    	if (mag_data_z != BMM150_ZAXIS_HALL_OVERFLOW_ADCVAL) {
    		if ((dev->trim_data.dig_z2 != 0) && (dev->trim_data.dig_z1 != 0)
    		&& (data_rhall != 0) && (dev->trim_data.dig_xyz1 != 0)) {
    			/*Processing compensation equations*/
    			process_comp_z0 = ((int16_t)data_rhall) - ((int16_t) dev->trim_data.dig_xyz1);
    			process_comp_z1 = (((int32_t)dev->trim_data.dig_z3) * ((int32_t)(process_comp_z0))) / 4;
    			process_comp_z2 = (((int32_t)(mag_data_z - dev->trim_data.dig_z4)) * 32768);
    			process_comp_z3 = ((int32_t)dev->trim_data.dig_z1) * (((int16_t)data_rhall) * 2);
    			process_comp_z4 = (int16_t)((process_comp_z3 + (32768)) / 65536);
    			retval = ((process_comp_z2 - process_comp_z1) / (dev->trim_data.dig_z2 + process_comp_z4));
    			/* saturate result to +/- 2 micro-tesla */
    			if (retval > BMM150_POSITIVE_SATURATION_Z) {
    				retval =  BMM150_POSITIVE_SATURATION_Z;
    			} else {
    				if (retval < BMM150_NEGATIVE_SATURATION_Z)
    					retval = BMM150_NEGATIVE_SATURATION_Z;
    			/* Conversion of LSB to micro-tesla*/
    			retval = retval / 16;
    		} else {
    			retval = BMM150_OVERFLOW_OUTPUT;
    	} else {
    		/* Overflow condition*/
    	return (int16_t)retval;
    o_o
    Contributor
    Glad you found your issue. If the part has been short-circuited, I cannot guarantee that will work with full performance, and would advise to replace it to be on the safe side.
    On the topic of compensation formula, I will double-check to confirm whether zero is a possible value, and therefore a bug in the API.
    o_o
