    BMP 280 accuracy
    BMP 280 accuracy
    szohar
    We are using the BMP280 in a production design.
    We messured few off them and we see in all an Absolute accuracy pressure errors of about 4hPa.
    The registers are set as follow
    ctrl_meas 0B10110111 //Temp OS 16X, Press OS 16x, Power Normal
    config 0B01010000 ////Inactive 125ms, IIR Filter coefx16, SPI OFF
    The Temp I am getting is 32C.
    I was using the compensation method given in the API example.
    What can be the issues that cases those accuracy problems.
    In the data sheet it is also mentioned that for better accuracy please contact the manufacturer, so I do.
    Sharon
    10 REPLIES 10
    Jet
    Occasional Contributor
    Hi Sir:
         Did you mean that you have verified all BMP280 and found the absolute accuracy pressure errors of about 4hPa?
         Could you tell us how many bmp280 sensors you have checked? Where did you get the reference value of ambient pressure?
         If you confirm your reference value correct, please offer your source code, first we will check them.
    Thanks for the replay.
    Yes, I do see absolute accuracy pressure errors of about 4hPa.
    I checked the issue on 5 different sensors. I used as reference two iPhones as well as a website that reports real time local presure.
    I can't send the full code it is few 100K lines of code. The relevant code is below.
    #define CntrlMeasDefault 0B10110111 //Temp OS 16X, Press OS 16x, Power Normal
    #define ConfigDefault 0B01010000 //Inactive 125ms, IIR Filter coefx16, SPI OFF
    s32 IS_BMP_Config()
    s32 com_rslt = ERROR;
    u8 CntrlMes=CntrlMeasDefault;
    u8 Config= ConfigDefault;
    I2C_routine(); // Initiate a pointer to the I2C routine
    com_rslt = bme280_init(&bme280); // Read DeviceID and the compensation parameters.
    com_rslt=bme280_write_register(BME280_CTRL_MEAS_REG,CntrlMes,(u8)1);
    com_rslt+=bme280_write_register(BME280_CONFIG_REG,Config,(u8)1);
    HAL_Delay(100);
    Read_Config_Reg();
    return com_rslt;
    s32 Get_BMP280_Bridge_Data(s32 *v_data_uncomp_temp_s32 ,s32 *v_data_uncomp_pres_s32)
    s32 com_rslt = BME280_INIT_VALUE;
    com_rslt = bme280_read_uncomp_temperature(v_data_uncomp_temp_s32);
    com_rslt += bme280_read_uncomp_pressure(v_data_uncomp_pres_s32);
    return com_rslt;
    double IS_Compensate_Pressure(s32 v_uncomp_pressure_s32)
    double var1, var2;
    int8_t rslt=BMP280_OK;
    double pressure=0;
    //rslt = null_ptr_check(dev);
    if (rslt == BMP280_OK)
    var1 = ((double) p_bme280->cal_param.t_fine / 2.0) - 64000.0;
    var2 = var1 * var1 * ((double) p_bme280->cal_param.dig_P6) / 32768.0;
    var2 = var2 + var1 * ((double) p_bme280->cal_param.dig_P5) * 2.0;
    var2 = (var2 / 4.0) + (((double) p_bme280->cal_param.dig_P4) * 65536.0);
    var1 = (((double)p_bme280->cal_param.dig_P3) * var1 * var1 / 524288.0 + ((double)p_bme280->cal_param.dig_P2) * var1) /
    524288.0;
    var1 = (1.0 + var1 / 32768.0) * ((double) p_bme280->cal_param.dig_P1);
    pressure = 1048576.0 - (double)v_uncomp_pressure_s32;
    if (var1 < 0 || var1 > 0)
    pressure = (pressure - (var2 / 4096.0)) * 6250.0 / var1;
    var1 = ((double)p_bme280->cal_param.dig_P9) * (pressure) * (pressure) / 2147483648.0;
    var2 = (pressure) * ((double)p_bme280->cal_param.dig_P8) / 32768.0;
    pressure = pressure + (var1 + var2 + ((double)p_bme280->cal_param.dig_P7)) / 16.0;
    else
    pressure = 0;
    rslt = BMP280_E_DOUBLE_COMP_PRESS;
    return pressure;
    * returns altitude in meters based on pressure and standard seaLevelpressure, both in hPa
    * standard seaLevelhPa = 1013.25
    float Get_Altitude(float Pressure)
    return (float)44330 * (1.0 - pow(Pressure / 1013.25, 0.19026)); // From feet converted to [M]
    Jet
    Hi Sir:
         I checked your source code and configuration, I didn't find any abnormal points.
        Could you offer your trim values of BMP280 sensor/ the raw data of termperature and pressure from sensor  / the compensated pressure and temperature ? I need to do further confirmation.
    See the paramter below.
    Sharon
    Details:27680
    Default:27680
    Decimal:27680
    Hex:0x6c20
    Binary:110110000100000
    Octal:066040
    Details:26163
    Default:26163
    Decimal:26163
    Hex:0x6633
    Binary:110011000110011
    Octal:063063
    Details:50
    Default:50
    Decimal:50
    Hex:0x32
    Binary:110010
    Octal:062
    Details:38057
    Default:38057
    Decimal:-27479
    Hex:0x94a9
    Binary:1001010010101001
    Octal:0112251
    Details:3024
    Default:3024
    Decimal:3024
    Hex:0xbd0
    Binary:101111010000
    Octal:05720
    Details:-10462
    Default:-10462
    Decimal:-10462
    Hex:0xd722
    Binary:1101011100100010
    Octal:0153442
    Details:6385
    Default:6385
    Decimal:6385
    Hex:0x18f1
    Binary:1100011110001
    Octal:014361
    Details:-7
    Default:-7
    Decimal:-7
    Hex:0xfff9
    Binary:1111111111111001
    Octal:0177771
    Details:-27
    Default:-27
    Decimal:-27
    Hex:0xffe5
    Binary:1111111111100101
    Octal:0177745
    Details:15500
    Default:15500
    Decimal:15500
    Hex:0x3c8c
    Binary:11110010001100
    Octal:036214
    Details:-14600
    Default:-14600
    Decimal:-14600
    Hex:0xc6f8
    Binary:1100011011111000
    Octal:0143370
    Details:6000
    Default:6000
    Decimal:6000
    Hex:0x1770
    Binary:1011101110000
    Octal:013560
    Details:0
    Default:0
    Decimal:0
    Hex:0x0
    Binary:0
    Octal:0
