    BMP 280 accuracy
    BMP 280 accuracy
    szohar
    We are using the BMP280 in a production design.
    We messured few off them and we see in all an Absolute accuracy pressure errors of about 4hPa.
    The registers are set as follow
    ctrl_meas 0B10110111 //Temp OS 16X, Press OS 16x, Power Normal
    config 0B01010000 ////Inactive 125ms, IIR Filter coefx16, SPI OFF
    The Temp I am getting is 32C.
    I was using the compensation method given in the API example.
    What can be the issues that cases those accuracy problems.
    In the data sheet it is also mentioned that for better accuracy please contact the manufacturer, so I do.
    Sharon
    10 REPLIES 10
    Jet
    Occasional Contributor
    Hi Sir:
         You still need to offer the raw data of termperature and pressure from sensor / the compensated pressure and temperature, I don't use my own sensor value to verify your trim values.
    Please see below.
    Your prompt help will be appricated.
    Uncompensated presure is
    Details:333767.375
    Decimal:333767
    Hex:0x517c7
    Compensated presure is
    Default:100180.547
    Decimal:100180
    Hex:0x18754
    Uncompensate Temp
    Default:516833
    Decimal:516833
    Hex:0x7e2e1
    Compensate Temp
    Details:2307
    Default:2307
    Decimal:2307
    Hex:0x903
    Jet
    Hi Sir:
         I used your trim values and your raw data, but got the different value of the pressure.
        Please see the following log which is that used your trim values and your raw data:
        BMP280_CTRL_MEAS_ADDR =0xb7,BMP280_CONFIG_ADDR =0x50
    BMP280 Shuttle Trim values
    dev->calib_param.dig_t1 = 27766
    dev->calib_param.dig_t2 = 26578
    dev->calib_param.dig_t3 = -1000
    dev->calib_param.dig_p1 = 36265
    dev->calib_param.dig_p2 = -10611
    dev->calib_param.dig_p3 = 3024
    dev->calib_param.dig_p4 = 3504
    dev->calib_param.dig_p5 = 214
    dev->calib_param.dig_p6 = -7
    dev->calib_param.dig_p7 = 15500
    dev->calib_param.dig_p8 = -14600
    dev->calib_param.dig_p9 = 6000
    BMP280 Single CHIP Trim values
    dev->calib_param.dig_t1 = 27680
    dev->calib_param.dig_t2 = 26163
    dev->calib_param.dig_t3 = 50
    dev->calib_param.dig_p1 = 38057
    dev->calib_param.dig_p2 = -10462
    dev->calib_param.dig_p4 = 6385
    dev->calib_param.dig_p5 = -7
    dev->calib_param.dig_p6 = -27
    Enter BMP280 Task Loop!
    UT: 516833, T32: 2307, Double_T: 23.068108
    UP: 333767, P32: 100248
    UT: 51681UT: 516833, T32: 2307, Double_T: 23.068108
    Frow above log, you can get my trim values, my sensor raw data  and output results, please see the following log:
    UT: 529941, T32: 2706, Double_T: 27.064492
    UP: 400952, P32: 102207
    UT: 529951, T32: 2707, Double_T: 27.067641
    UP: 400949, P32: 102207
    Compared with other sensors, these results are normal within the permitted range.
    Please see the attachment, which is my source code.
    Thanks for the information.
    I will check to understand why there is a different in compensated presure but the different that you get is about 0.6hPa, we are getting diffrences of over 4hPa which is a major trouble for us.
    Why the difference compared to reality can be so major out of spec dramaticaly?
    Sharon
    Also looks as some of the variables you entered are switched as an example you can see that P2 and P3 are switched.
