    BMP280 MSB temperature is sometimes corrupted
    Jussi
    I am running BMP with I2C using nrf9160 as MCU and zephyr RTOS and zephyrs BME280 drivers as my SW. Using forced mode and recording pressure approximately once/10min(or every 5 seconds for testing purposes)
    My problem is that I sometimes(maybe 2% of readings) get really strange pressure values. I've tried to debug the issue and found out that pressure registers are actually probably ok, but temperature is sometimes somehow corrupted and that causes the compensated pressure to be quite off the limits too. This is the piece of code in zephyr drivers that read the result registers in one burst read: https://github.com/zephyrproject-rtos/zephyr/blob/d431b56587a9afbee091180d3511257a148a359f/drivers/s...
    // If I print out the register values after they are read is see this:
    // Valid registers(F7-FC):       53 00 d0 7e 8d 00
    // And when we hit the problem:  52 fd c0 3e 85 00
    // It looks like this one bit 3->7 causes temperature to be interpreted as something like
    // -50C instead of +20C and pressure to be 870hPa instead of 980hPa
    I've been eyeballing the drivers and tried to sniff the traffic with scope but my conclusion is always the same. Everything looks to be correct, sensor just sends a wrong value. Any ideas what could be causing this?
    7 REPLIES 7
    I have tried with multiple different sensors and boards. I can open the attachment just fine. I'll just copy paste the log here.
    [00:00:05.230,133] <dbg> bmp280.read_pressure: Uncom data. Temp: 509328 (0x7c590), Press: 326160 (0x4fa10)
    [00:00:05.230,163] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:05.230,255] <dbg> bmp280.read_pressure: Got compensated pressure: 998.91
    [00:00:10.220,397] <dbg> bmp280.read_pressure: Uncom data. Temp: 509328 (0x7c590), Press: 326160 (0x4fa10)
    [00:00:10.220,428] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:10.220,520] <dbg> bmp280.read_pressure: Got compensated pressure: 998.91
    [00:00:15.220,672] <dbg> bmp280.read_pressure: Uncom data. Temp: 509304 (0x7c578), Press: 326156 (0x4fa0c)
    [00:00:15.220,703] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:00:15.220,794] <dbg> bmp280.read_pressure: Got compensated pressure: 998.90
    [00:00:20.220,947] <dbg> bmp280.read_pressure: Uncom data. Temp: 509328 (0x7c590), Press: 326156 (0x4fa0c)
    [00:00:20.220,977] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:20.221,069] <dbg> bmp280.read_pressure: Got compensated pressure: 998.92
    [00:00:25.220,214] <dbg> bmp280.read_pressure: Uncom data. Temp: 509312 (0x7c580), Press: 326160 (0x4fa10)
    [00:00:25.220,245] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:25.220,336] <dbg> bmp280.read_pressure: Got compensated pressure: 998.90
    [00:00:30.220,489] <dbg> bmp280.read_pressure: Uncom data. Temp: 509328 (0x7c590), Press: 326144 (0x4fa00)
    [00:00:30.220,520] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:30.220,611] <dbg> bmp280.read_pressure: Got compensated pressure: 998.94
    [00:00:35.220,764] <dbg> bmp280.read_pressure: Uncom data. Temp: 509312 (0x7c580), Press: 326168 (0x4fa18)
    [00:00:35.220,794] <dbg> bmp280.read_pressure: Got compensated temperature: 21.26
    [00:00:35.220,886] <dbg> bmp280.read_pressure: Got compensated pressure: 998.89
    [00:00:40.221,038] <dbg> bmp280.read_pressure: Uncom data. Temp: 509304 (0x7c578), Press: 326184 (0x4fa28)
    [00:00:40.221,069] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:00:40.221,160] <dbg> bmp280.read_pressure: Got compensated pressure: 998.86
    [00:00:45.221,313] <dbg> bmp280.read_pressure: Uncom data. Temp: 509304 (0x7c578), Press: 326164 (0x4fa14)
    [00:00:45.221,343] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:00:45.221,435] <dbg> bmp280.read_pressure: Got compensated pressure: 998.89
    [00:00:50.221,618] <dbg> bmp280.read_pressure: Uncom data. Temp: 247168 (0x3c580), Press: 326140 (0x4f9fc)
    [00:00:50.221,649] <dbg> bmp280.read_pressure: Got compensated temperature: -60.00
    [00:00:50.221,740] <dbg> bmp280.read_pressure: Got compensated pressure: 873.32
    [00:00:50.241,699] <dbg> bmp280.read_pressure: Uncom data. Temp: 509368 (0x7c5b8), Press: 326144 (0x4fa00)
    [00:00:50.241,760] <dbg> bmp280.read_pressure: Got compensated temperature: 21.27
    [00:00:50.241,851] <dbg> bmp280.read_pressure: Got compensated pressure: 998.96
    [00:00:55.222,015] <dbg> bmp280.read_pressure: Uncom data. Temp: 247192 (0x3c598), Press: 326132 (0x4f9f4)
    [00:00:55.222,045] <dbg> bmp280.read_pressure: Got compensated temperature: -59.99
    [00:00:55.222,137] <dbg> bmp280.read_pressure: Got compensated pressure: 873.34
    [00:00:55.242,095] <dbg> bmp280.read_pressure: Uncom data. Temp: 247224 (0x3c5b8), Press: 326148 (0x4fa04)
    [00:00:55.242,156] <dbg> bmp280.read_pressure: Got compensated temperature: -59.98
    [00:00:55.242,248] <dbg> bmp280.read_pressure: Got compensated pressure: 873.33
    [00:00:55.265,228] <dbg> bmp280.read_pressure: Uncom data. Temp: 247264 (0x3c5e0), Press: 326180 (0x4fa24)
    [00:00:55.265,289] <dbg> bmp280.read_pressure: Got compensated temperature: -59.97
    [00:00:55.265,380] <dbg> bmp280.read_pressure: Got compensated pressure: 873.30
    [00:00:55.293,304] <dbg> bmp280.read_pressure: Uncom data. Temp: 247304 (0x3c608), Press: 326188 (0x4fa2c)
    [00:00:55.293,334] <dbg> bmp280.read_pressure: Got compensated temperature: -59.96
    [00:00:55.293,426] <dbg> bmp280.read_pressure: Got compensated pressure: 873.31
    [00:01:00.222,564] <dbg> bmp280.read_pressure: Uncom data. Temp: 247176 (0x3c588), Press: 326132 (0x4f9f4)
    [00:01:00.222,595] <dbg> bmp280.read_pressure: Got compensated temperature: -60.00
    [00:01:00.222,686] <dbg> bmp280.read_pressure: Got compensated pressure: 873.33
    [00:01:05.222,839] <dbg> bmp280.read_pressure: Uncom data. Temp: 509288 (0x7c568), Press: 326144 (0x4fa00)
    [00:01:05.222,869] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:01:05.222,961] <dbg> bmp280.read_pressure: Got compensated pressure: 998.92
    [00:01:05.242,919] <dbg> bmp280.read_pressure: Uncom data. Temp: 509360 (0x7c5b0), Press: 326168 (0x4fa18)
    [00:01:05.242,980] <dbg> bmp280.read_pressure: Got compensated temperature: 21.27
    [00:01:05.243,072] <dbg> bmp280.read_pressure: Got compensated pressure: 998.91
    [00:01:05.266,052] <dbg> bmp280.read_pressure: Uncom data. Temp: 247264 (0x3c5e0), Press: 326164 (0x4fa14)
    [00:01:05.266,113] <dbg> bmp280.read_pressure: Got compensated temperature: -59.97
    [00:01:05.266,204] <dbg> bmp280.read_pressure: Got compensated pressure: 873.33
    [00:01:10.222,351] <dbg> bmp280.read_pressure: Uncom data. Temp: 247160 (0x3c578), Press: 326164 (0x4fa14)
    [00:01:10.222,381] <dbg> bmp280.read_pressure: Got compensated temperature: -60.00
    [00:01:10.222,473] <dbg> bmp280.read_pressure: Got compensated pressure: 873.28
    [00:01:15.222,625] <dbg> bmp280.read_pressure: Uncom data. Temp: 509304 (0x7c578), Press: 326152 (0x4fa08)
    [00:01:15.222,656] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:01:15.222,747] <dbg> bmp280.read_pressure: Got compensated pressure: 998.91
    [00:01:15.242,706] <dbg> bmp280.read_pressure: Uncom data. Temp: 247224 (0x3c5b8), Press: 326172 (0x4fa1c)
    [00:01:15.242,767] <dbg> bmp280.read_pressure: Got compensated temperature: -59.98
    [00:01:15.242,858] <dbg> bmp280.read_pressure: Got compensated pressure: 873.30
    [00:01:20.223,022] <dbg> bmp280.read_pressure: Uncom data. Temp: 509296 (0x7c570), Press: 326168 (0x4fa18)
    [00:01:20.223,052] <dbg> bmp280.read_pressure: Got compensated temperature: 21.25
    [00:01:20.223,144] <dbg> bmp280.read_pressure: Got compensated pressure: 998.88
    [00:01:20.243,103] <dbg> bmp280.read_pressure: Uncom data. Temp: 247200 (0x3c5a0), Press: 326172 (0x4fa1c)
    [00:01:20.243,164] <dbg> bmp280.read_pressure: Got compensated temperature: -59.99
    [00:01:20.243,255] <dbg> bmp280.read_pressure: Got compensated pressure: 873.29
    [00:01:25.223,419] <dbg> bmp280.read_pressure: Uncom data. Temp: 247224 (0x3c5b8), Press: 326172 (0x4fa1c)
    [00:01:25.223,449] <dbg> bmp280.read_pressure: Got compensated temperature: -59.98
    [00:01:25.223,541] <dbg> bmp280.read_pressure: Got compensated pressure: 873.30
    [00:01:30.223,693] <dbg> bmp280.read_pressure: Uncom data. Temp: 509520 (0x7c650), Press: 326192 (0x4fa30)
    [00:01:30.223,724] <dbg> bmp280.read_pressure: Got compensated temperature: 21.32
    [00:01:30.223,815] <dbg> bmp280.read_pressure: Got compensated pressure: 998.95
    [00:01:30.243,774] <dbg> bmp280.read_pressure: Uncom data. Temp: 247416 (0x3c678), Press: 326236 (0x4fa5c)
    [00:01:30.243,835] <dbg> bmp280.read_pressure: Got compensated temperature: -59.92
    [00:01:30.243,927] <dbg> bmp280.read_pressure: Got compensated pressure: 873.29
    [00:01:35.223,083] <dbg> bmp280.read_pressure: Uncom data. Temp: 247464 (0x3c6a8), Press: 326196 (0x4fa34)
    [00:01:35.223,114] <dbg> bmp280.read_pressure: Got compensated temperature: -59.91
    [00:01:35.223,205] <dbg> bmp280.read_pressure: Got compensated pressure: 873.37
    [00:01:40.223,388] <dbg> bmp280.read_pressure: Uncom data. Temp: 509712 (0x7c710), Press: 326252 (0x4fa6c)
    [00:01:40.223,419] <dbg> bmp280.read_pressure: Got compensated temperature: 21.38
    [00:01:40.223,510] <dbg> bmp280.read_pressure: Got compensated pressure: 998.95
    [00:01:40.243,469] <dbg> bmp280.read_pressure: Uncom data. Temp: 509752 (0x7c738), Press: 326272 (0x4fa80)
    [00:01:40.243,530] <dbg> bmp280.read_pressure: Got compensated temperature: 21.39
    [00:01:40.243,621] <dbg> bmp280.read_pressure: Got compensated pressure: 998.94
    [00:01:40.266,571] <dbg> bmp280.read_pressure: Uncom data. Temp: 509800 (0x7c768), Press: 326304 (0x4faa0)
    [00:01:40.266,632] <dbg> bmp280.read_pressure: Got compensated temperature: 21.41
    [00:01:40.266,723] <dbg> bmp280.read_pressure: Got compensated pressure: 998.91
    [00:01:40.294,647] <dbg> bmp280.read_pressure: Uncom data. Temp: 509848 (0x7c798), Press: 326308 (0x4faa4)
    [00:01:40.294,677] <dbg> bmp280.read_pressure: Got compensated temperature: 21.42
    [00:01:40.294,769] <dbg> bmp280.read_pressure: Got compensated pressure: 998.93
    [00:01:45.223,907] <dbg> bmp280.read_pressure: Uncom data. Temp: 509816 (0x7c778), Press: 326340 (0x4fac4)
    [00:01:45.223,937] <dbg> bmp280.read_pressure: Got compensated temperature: 21.41
    [00:01:45.224,029] <dbg> bmp280.read_pressure: Got compensated pressure: 998.86
    [00:01:50.223,175] <dbg> bmp280.read_pressure: Uncom data. Temp: 509952 (0x7c800), Press: 326384 (0x4faf0)
    [00:01:50.223,205] <dbg> bmp280.read_pressure: Got compensated temperature: 21.46
    [00:01:50.223,297] <dbg> bmp280.read_pressure: Got compensated pressure: 998.85
    [00:01:55.223,449] <dbg> bmp280.read_pressure: Uncom data. Temp: 510064 (0x7c870), Press: 326392 (0x4faf8)
    [00:01:55.223,480] <dbg> bmp280.read_pressure: Got compensated temperature: 21.49
    [00:01:55.223,571] <dbg> bmp280.read_pressure: Got compensated pressure: 998.90
    [00:02:00.223,724] <dbg> bmp280.read_pressure: Uncom data. Temp: 510176 (0x7c8e0), Press: 326444 (0x4fb2c)
    [00:02:00.223,754] <dbg> bmp280.read_pressure: Got compensated temperature: 21.53
    [00:02:00.223,846] <dbg> bmp280.read_pressure: Got compensated pressure: 998.87
    And the codes:
    static int init() {
      int err = 0;
      if (initialized) {
        return 0;
      bmp.dev_id = I2C_ADD_BMP280;
      bmp.intf = BMP280_I2C_INTF;
      bmp.delay_ms = delay_ms;
      bmp.read = i2c_reg_read;
      bmp.write = i2c_reg_write;
      err = bmp280_init(&bmp);
      if (err != 0) {
        LOG_DBG("bmp280_init failed: %d", err);
        return err;
      err = bmp280_get_config(&conf, &bmp);
      if (err != 0) {
        return err;
      LOG_DBG("os_temp=%u, os_pres=%u, odr=%u, filter=%u, spi3w_en=%u",
              conf.os_temp, conf.os_pres, conf.odr, conf.filter, conf.spi3w_en);
      conf.os_temp = BMP280_OS_2X;
      conf.filter = BMP280_FILTER_COEFF_2;
      conf.os_pres = BMP280_OS_4X;
      // Not used in forced mode actually
      conf.odr = BMP280_ODR_1000_MS;
      // Note that this function internally sets bmp->conf = conf
      err = bmp280_set_config(&conf, &bmp);
      if (err != 0) {
        return err;
      initialized = true;
      return err;
    static int read_pressure(float* pressure_hpa_out) {
      int err = init();
      if (err) {
        return err;
      // Settnig the power mode to forced, triggers the measurement
      err = bmp280_set_power_mode(BMP280_FORCED_MODE, &bmp);
      if (err != 0) {
        return err;
      struct bmp280_uncomp_data ucomp_data;
      double pres, temperature;
      // According to  data sheet, measurement time should be around 12ms with these settings
      // If we wait 11+2=13ms result seems to be ready according to experiments
      k_sleep(K_MSEC(11));
      struct bmp280_status status;
      // Just in case sensor is not ready yet, poll the status register for a while
      int max_wait = 5;
      do {
        k_sleep(K_MSEC(2));
        err = bmp280_get_status(&status, &bmp);
        if (err != 0) {
          return err;
        LOG_DBG("measuring=%s, im_update=%s", status.measuring ? "true" : "false", status.im_update ? "true" : "false");
      } while (status.measuring && max_wait-- > 0);
      // Reading the data is a delegant business with this driver. First read raw data.
      err = bmp280_get_uncomp_data(&ucomp_data, &bmp);
      if (err != 0) {
        return err;
      LOG_DBG("Uncom data. Temp: %d (0x%X), Press: %u (0x%X)",
              ucomp_data.uncomp_temp, ucomp_data.uncomp_temp, ucomp_data.uncomp_press, ucomp_data.uncomp_press);
      // Then we have to read the compensated temperature, although we don't really need it for anything
      // This sets things straight inside the driver
      err = bmp280_get_comp_temp_double(&temperature, ucomp_data.uncomp_temp, &bmp);
      if (err != 0) {
        return err;
      LOG_DBG("Got compensated temperature: " LONE_FLOAT_FORMATTER, LONE_FLOAT_ARG((float)temperature));
      // And then we can read the compensated pressure
      err = bmp280_get_comp_pres_double(&pres, ucomp_data.uncomp_press, &bmp);
      if (err != 0) {
        return err;
      // From Pa to hPa
      *pressure_hpa_out = (float)(pres / 100);
      LOG_DBG("Got compensated pressure: " LONE_FLOAT_FORMATTER, LONE_FLOAT_ARG(*pressure_hpa_out));
      return 0;
    Yanchao
    Yesteday, I test BMP280 pressure and temp data with COINES/APP2.0/BMP280 shuttle, haven't find this issue.
    From your code and log, BMP280 configed in Force mode, before read temp/press register data, there 5x2ms round read bmp280_get_status(), your sample interval nearly 5sec.
    One suggestion, in Force mode, make 5x100ms round read bmp280_get_status().
    Another suggestion, try to use Normal mode to get press/temp data, and log data as API examples.
    Wait for your feedback!
    Best regards.
