    BMP280: Unable to change power mode
    user1397215
    I am experiencing an issue with the BMP280 where writing to 0xF4 (ctrl_meas) register only results in changes being made for the osrs_p and osrs_t fields. I can see my I2C writes only apply to these fields in the register and not the power mode (last 2 bits). My problem is my BMP280 is currently in sleep mode it seems and stuck in this mode permanently (from reading the 0xF4 register I keep getting xxxx xx00, depending on how I set up osrs_t and osrs_p). The chip ID reading is correct. I have tried checking the value I am sending over a scope and it looks like I am sending the correct info.
    Hello user1397215,
    The bits mode[1:0] in 0xF4 register determined the power mode.
    You could see data sheet and github drive how to change power mode.
    https://github.com/BoschSensortec/BMP280_driver/blob/master/examples/pressure.c
    /* Always set the power mode after setting the configuration */
    rslt = bmp280_set_power_mode(BMP280_NORMAL_MODE, &bmp);
    Thanks @BSTRobin I was able to get this working now. I found that the sensor was constantly set to sleep mode (it seemed I was not reading it at all when I set it to Forced mode). So got it working now by setting it to Normal mode, performing a read, then back to sleep mode.
    Good news, user1397215
