12-22-2021 07:01 AM
I have a question for Bosch Sensortec “BMP280” digital pressure sensor. I saw that the production of this sensor has stopped. If so, what is a compatible sensor that can be used instead of the BMP280 sensor? I'm waiting for your help on the subject.
Best Regards,
12-28-2021 06:54 AM
Hello m_d,
No other recommendations, refer to the recommended on the official website that previous mentioned.
12-09-2023 07:42 PM - edited 12-09-2023 07:42 PM
You can try to use BME280. They are pin-to-pin compatible, but the package is slightly larger. But it is possible to solder it instead of BMP 280.
3 weeks ago
Hello m_d,
Usually, with the improvement of technology and process, new sensors have smaller dimensions and better performance than old sensors. We should try to choose new sensors for use in the new design, rather than letting the new sensors be compatible with the old ones.
I recommend using the latest BMP5xy pressure sensor(https://www.bosch-sensortec.com/products/environmental-sensors/pressure-sensors/) in your design.
