    BMP280 self-test fails
    On our board we've integrated a BMP280 that we drive with I²C. I use the driver provided by https://github.com/BoschSensortec/BMP280_driver
    However the self-test fails for t3 check: the value 50 is not within the range [-3000, -1000]  (https://github.com/BoschSensortec/BMP280_driver/blob/master/bmp280_defs.h#L304-L305)
    Debug traces:
    13:33:36.631733 😧 read: 0xd0: @00: 58
    13:33:36.631748 😧 read: 0x88: @00: d5
    13:33:36.631761 😧 read: 0x88: @01: 6a
    13:33:36.631775 😧 read: 0x88: @02: ac
    13:33:36.631789 😧 read: 0x88: @03: 64
    13:33:36.631804 😧 read: 0x88: @04: 32
    13:33:36.631821 😧 read: 0x88: @05: 00
    13:33:36.631836 😧 read: 0x88: @06: fb
    13:33:36.639739 😧 read: 0x88: @07: 94
    13:33:36.639844 😧 read: 0x88: @08: 9e
    13:33:36.639857 😧 read: 0x88: @09: d6
    13:33:36.639870 😧 read: 0x88: @0a: d0
    13:33:36.639889 😧 read: 0x88: @0b: 0b
    13:33:36.639907 😧 read: 0x88: @0c: 26
    13:33:36.639924 😧 read: 0x88: @0d: 20
    13:33:36.639939 😧 read: 0x88: @0e: 62
    13:33:36.639955 😧 read: 0x88: @0f: ff
    13:33:36.639971 😧 read: 0x88: @10: f9
    13:33:36.639988 😧 read: 0x88: @11: ff
    13:33:36.640005 😧 read: 0x88: @12: 8c
    13:33:36.640023 😧 read: 0x88: @13: 3c
    13:33:36.640040 😧 read: 0x88: @14: f8
    13:33:36.640055 😧 read: 0x88: @15: c6
    13:33:36.640072 😧 read: 0x88: @16: 70
    13:33:36.640090 😧 read: 0x88: @17: 17
    13:33:36.645969 OK:      875:    27349 vs.    19000/   35000
    13:33:36.646048 OK:      881:    25772 vs.    22000/   30000
    13:33:36.646063 ERR:     884:       50 vs.    -3000/   -1000
    13:33:36.646095 OK:      893:    38139 vs.    30000/   42000
    13:33:36.646109 OK:      899:   -10594 vs.   -12970/   -8000
    13:33:36.646125 OK:      905:     3024 vs.    -5000/    8000
    13:33:36.646141 OK:      911:     8230 vs.   -10000/   18000
    13:33:36.646158 OK:      917:     -158 vs.     -500/    1100
    13:33:36.646174 OK:      923:       -7 vs.    -1000/    1000
    13:33:36.646190 OK:      929:   -14600 vs.   -30000/   10000
    13:33:36.662018 OK:      935:     6000 vs.   -10000/   30000
    13:33:36.662074 E:  128: self-test failed: -9
    Since I do not see the values in the datasheet, I'm unsure where the problem lies: code (-1000 value is too low) or in the chip (i.e. at production time).
    I have tested with two chips and both show 50 (but have some different values on other fields):
    12:56:50.979826 OK:      879:    27608 vs.    19000/   35000
    12:56:50.979848 OK:      885:    25836 vs.    22000/   30000
    12:56:50.979882 ERR:     888:       50 vs.    -3000/   -1000
    12:56:50.979914 OK:      896:    39409 vs.    30000/   42000
    12:56:50.979937 OK:      902:   -10632 vs.   -12970/   -8000
    12:56:50.979965 OK:      908:     3024 vs.    -5000/    8000
    12:56:50.979998 OK:      914:     8011 vs.   -10000/   18000
    12:56:50.995638 OK:      920:     -293 vs.     -500/    1100
    12:56:50.995815 OK:      926:       -7 vs.    -1000/    1000
    12:56:50.995860 OK:      932:   -14600 vs.   -30000/   10000
    12:56:50.995901 OK:      938:     6000 vs.   -10000/   30000
    Any help appreciated.
    Marc.
    Re: BMP280 self-test fails
    Thanks for the feedback ,the information will be sent back to the  internal team.
    Hi marto,
    Can you confirm that the status (0xF3) register's bit 0 (im_update) is 0 before you trigger the self-test? Also, can you read out the laser markings on the top of the sensor?
    kgoveas
    I confirm that register 0xf3 returns 0x00.
    Regarding the marking I have two pre-prod series:
    -  919 KS
    -  9N2 KS
    Both returns 50 for the test.
    (sorry for delay, I thought that I would receive notifications via e-mail).
    Any news/idea about this problem ?
    Marc.
