Hi guys,
I am new to this and need some help. Thank you in advance.
I have an application board 3.0 (APP3) with a BMP390 Shuttle Board 3.0 on it.
I have installed Development Desk 2.0 (UI Ver 3.25.0.0) on Windows 10.
My App3 is connected to my PC with Windows 10 through a USB cable.
I can connect to the APP3 and DD2 displays the sensor main menu. (a graph show pressure and temperature)
But I don't see any sensor output, just shows the main page of the (pressure & temperature) display.
I have done the following (step by step): still don't see any data.
a. updated window driver and was able to recognize the USB interface and connect.
b. update the bootloader from COINES\v2.7.0\firmware\app3.0\bootloader_update.
c. updated the DelopmentDesktop_2.0_Firmware_v1.9.bin. from COINES directory.
Still, I don’t see any action from APP3/BMP390. Just an empty main graph table with no data.
Note: I did all this because, when I received the APP3/BMP390 the boards were not showing any data and after all
With these updates, the situation has not changed.
I am lost and need some help.
1. Both LEDs on my app3 are lit, orange(good pwr), and RED. is this right? Should RED be GREEN?
2. When I try to update flash from DD2 bootloader menu with Blue LED on.
using DD2 in Boot mode, ‘Setting’ -> ‘Firmware upgrade’ menu. using file
“DevelopmentDesktop_2.0_frimware_V3.5.fwu2” the system indicate
“Firmware update in progress...BUT just sits in this position forever, meaning flash
never completes updating. I have waited 1/2 hour and still no indication of what going on.
Appreciate any help --- thank you
Hi jsayed,
It is not correct when red LED is on. You can refer "C:\COINES\v2.7.0\doc\BST-DHW-AN013.pdf" document and check if you follow the operation step by step.
Hi, someone, anyone PLEASE -- even a hint on my above question (previous remark)..... THANK YOU
Hi jsayed,
COINES environment didn't support to display GUI, you could see it from application note under "C:\COINES\v2.7.0\doc".
