    BMP390 - data is not displayed on Application board3/BMP390 shuttle board and DD2.
    jsayed
    Hi guys,
    I am new to this and need some help. Thank you in advance.
    I have an application board 3.0 (APP3) with a BMP390 Shuttle Board 3.0 on it.
    I have installed Development Desk 2.0 (UI Ver 3.25.0.0) on Windows 10.
    My App3 is connected to my PC with Windows 10 through a USB cable.
    I can connect to the APP3 and DD2 displays the sensor main menu. (a graph show pressure and temperature)
    But I don't see any sensor output, just shows the main page of the (pressure & temperature) display.
     I have done the following (step by step): still don't see any data.
    a. updated window driver and was able to recognize the USB interface and connect.
    b. update the bootloader from COINES\v2.7.0\firmware\app3.0\bootloader_update.
    c. updated the DelopmentDesktop_2.0_Firmware_v1.9.bin. from COINES directory.
      Still, I don’t see any action from APP3/BMP390. Just an empty main graph table with no data.
    Note: I did all this because, when I received the APP3/BMP390 the boards were not showing any data and after all
    With these updates, the situation has not changed.
    I am lost and need some help.
    1. Both LEDs on my app3 are lit, orange(good pwr), and RED. is this right?  Should RED be GREEN?
    2. When I try to update flash from DD2 bootloader menu with Blue LED on.
      using DD2 in Boot mode, ‘Setting’ -> ‘Firmware upgrade’ menu. using file
      “DevelopmentDesktop_2.0_frimware_V3.5.fwu2” the system indicate
      “Firmware update in progress...BUT just sits in this position forever, meaning flash
      never completes updating. I have waited 1/2 hour and still no indication of what going on.
      Appreciate any help --- thank you
    kgoveas
    Hi @jsayed ,
    Does your configuration/setup look similar to the one attached? I tried your setup on a clean PC (without any previous installations of Development Desktop 2.0 or COINES). Can you please confirm the same with screenshots?
