    BMP581 NWM access
    BMP581 NWM access
    Jule
    I evaluating the NVM of product BMP581 and struggle with the reading procedure.
    I followed instructions in datasheet and this is my Python code:
           self.writeRegister(0x37,int(f'11000000',2)) # Switch to standby
            time.sleep(0.1)
            x28 = format(self.readRegister(0x28),"08b") # Read status
            if x28[4:7]=='001': # No error and ready
                for reg in range(0x26, 0x22, -1😞
                    #print(f'Loop {reg} Register {0x00+reg}')
                    self.writeRegister(0x2B,int(reg)) # Write address
                    self.writeRegister(0x7F,int(0x5D)) # Write first read command
                    self.writeRegister(0x7F,int(0xA5)) # Write second read command
                    #time.sleep(0.1)
                        NVM1 = format(self.readRegister(0x2C),"08b") # Read register
                        NVM2 = format(self.readRegister(0x2D),"08b") # Read register
                        uid= uid + NVM2 + NVM1
                        print(f'Register {hex(reg)} read {NVM1} {NVM2}!')
                    else:
                        print(f'NVM read {hex(reg)} not ready')
            else:
                print(f'NVM not ready')
    All readings from the registers 0x2C and 0x2D always 0x00. What is wrong?
    Kind regards,
    Jule
    Please see the attached "How to use BMP581 NVM to store the offset from end-of-line calibration.pdf" to see if you can make it work on your side.
    Are you able to get the BMP581 NVM access working on your side?
