11-15-2023 12:59 PM
From the datasheet of BMP581, i don't see any section regarding the sensor calibration.
Is there any way to calibrate the sensor with firmware.I have checked the https://github.com/BoschSensortec/BMP5-Sensor-API code for calibration and couldn't find any code.
How do we calibrate BMP581?
11-15-2023 04:22 PM
Hi Vaishnavi,
Do you mean sensor data trimming(like BMP3) or pressure value calibration for application?
11-16-2023 05:23 AM
Hi BSTRobin,
By calibration,I mean pressure value calibration for our application.
11-29-2023 10:57 AM
Hi Vaishnavi,
Usually, calibration of barometers requires laboratory conditions, obtaining the value of a standard barometer through testing equipment, and calculating the offset of the sensor.
