    BMP581 water level measurement
    PeterMark
    Hi
    I want to measure the water level with bmp581.
    So, how does this sensor track water levels with mm precision?
    Bosch Video (84) Detecting the water level of a washing machine powered by BMP390 - seems to be suggested by YouTube.
    Is there any example code or guide document I can refer to?
    8 REPLIES 8
    Hi PeterMark,
    Thank you for your message. We gladly publish all publicly available information, but unfortunately we are not able to share the requested information within the community as it requires an NDA. If you need any further information on this topic, please get in contact with one of our official distributors or sales representatives to allow us to review each project on a case-by-case basis.
    Kerem
    Hello, I'm working on a similar project. I need to determine the height of water passing through a pipe. I want to use BMP581 for this purpose. Can you help me with this? Thank you.
    Hi Kerem,
    Sorry. We haven't got your point about "I need to determine the height of water passing through a pipe". Could you give detailed description about it? Thanks.
    Hi Kerem,
    Two pressure sensors are used in the washing machine. When the washing machine is in operation, as the water level rises, the water level height can be calculated based on the pressure difference between the two pressure sensors. After the washing machine is drained, it can be approximately assumed that the pressure difference between the two air pressure sensors inside the washing machine is very small.
    You need to confirm if your application scenario is the same as the application of washing machine water level detection? If no, you can give detailed descripion for your application.
