    BMX055 SPI Mag values
    Hi! Ive been working with the BMX055 and been trying to implement with SPI and havent been sucssefull with the reading in the magnetometer. I received the information that using the Mag in I2C and trying SPI after, something should be done to change the pin. I honestly didnt understand and would like to know if somoene could help me. I leave my program for arduino below hoping that somoene could help me or know what the problem is, since i can only reado 0,0,0 from the mag in SPI. And since i've used it in I2C and everything worked fine, i think is probably something that im missing.
    Thank you very much for your attention and help!
    #include <SPI.h>
    int CSB1 = A1;
    int CSB2 = A2;
    int CSB3 = A3;
    unsigned int x_lsb = 0x02;
    unsigned int y_lsb = 0x04;
    unsigned int z_lsb = 0x06;
    const byte READ = 0b10000000;
    unsigned long elp_time = micros();
    unsigned long read_time = micros();
    void setup() {
    pinMode(CSB1, OUTPUT);
    pinMode(CSB2, OUTPUT);
    pinMode(CSB3, OUTPUT);
    Serial.begin(115200);
    SPI.begin();
    SPI.setClockDivider(SPI_CLOCK_DIV64);
    SPI.setBitOrder(MSBFIRST);
    SPI.setDataMode(SPI_MODE0);
    digitalWrite(CSB1, HIGH);
    digitalWrite(CSB2, HIGH);
    digitalWrite(CSB3, HIGH);
    int readAcc(unsigned int coor) {
    int aux;
    digitalWrite(CSB1, LOW);
    SPI.transfer(0x80 + coor);
    aux = SPI.transfer(0x00);
    if (aux & 1) {
    aux = aux >> 4;
    SPI.transfer(0x80 + coor + 1);
    aux += (SPI.transfer(0x00) << 4);
    if (aux & 0x800)
    aux &= ~(0x800);
    return aux;
    else
    return 0;
    //delay(50);
    int readGyr(unsigned int coor) {
    int lsb;
    int msb;
    int aux;
    digitalWrite(CSB2, LOW);
    lsb = SPI.transfer(0x00);
    msb = SPI.transfer(0x00);
    aux = msb;
    if (lsb & 0x80) {
    lsb = ~lsb;
    lsb &= 0x7F;
    lsb++;
    if (msb & 0x80) {
    msb = ~msb;
    msb &= 0x7F;
    msb++;
    if (aux & 0x80) {
    aux = (msb << 8 )+ lsb;
    aux = ~aux;
    aux++;
    else {
    return aux;
    int readMag(unsigned int coor) {
    int aux;
    SPI.transfer(0xC0 + coor);
    aux = (SPI.transfer(0x00) >> 3);
    digitalWrite(CSB3, LOW);
    SPI.transfer(0xC0 + coor + 1);
    aux += (SPI.transfer(0x00) << 5);
    return aux;
    void loop() {
    // if (micros()-read_time > 5){
    // read_time = micros();
    int x, y, z;
    x = readAcc(x_lsb);
    y = readAcc(y_lsb);
    z = readAcc(z_lsb);
    //Serial.print("Acc x:");
    // Serial.print(x);
    // Serial.print(",");
    // Serial.print(y);
    // Serial.println(z);
    x = readGyr(x_lsb);
    y = readGyr(y_lsb);
    z = readGyr(z_lsb);
    // Serial.print(x);
    // Serial.print(y);
    x = readMag(x_lsb);
    y = readMag(y_lsb);
    z = readMag(z_lsb);
    Serial.print(x);
    Serial.print(",");
    Serial.print(y);
    Serial.print(",");
    Serial.println(z);
    Tags (3)
    Re: BMX055 SPI Mag values
    If you have  logical analyzer waveform, please provide it to us. BMM150 need initialize by setting register 0x4B, 0x4C.
