06-11-2019 11:29 AM
Dear all,
Recently I have acquired a bmx055 and I having some doubts regarding the data conversion and offset compensation.
According to the datasheet of the bmx055 (https://ae-bst.resource.bosch.com/media/_tech/media/datasheets/BST-BMX055-DS000.pdf😞
1 - The fast compensation for the accelerometer must be done in the 2g range (page 31). However, if I decide to switch the range afterwards for 16g, for example, will the offset compensation still be valid?
2 - The accelerometer data is a 12 bit word for each axis, but what are the units for the raw data? I would like to convert from g's to m/s^2 and I can only found the sensitivity in LSB/g in the datasheet
3 - I was trying to implement the fast compensation offset for the gyroscope (page 85 of the datasheet) but I am having some troubles
3.1. According to the datasheet I have to enable the GYR 0x32 <0:2> bits for each axis. But can I enable all at the same time? Or do I need to one at each time like it is recommended for the accelerometer data?
3.2. Then I need to set the wordlength and enable the start bit GYR 0x32 <3>to start the compensation right?
3.3. Once the compensation as ended the GYR 0x32 <3> bit is reset to 0, but where are the fast compensation values saved? in the GYR 0x36 register? or in the 0x37, 0x38, 0x39 (for each x, y and z axis)? If in the GYR 0x36 register should I trim and cast each axis value so that it becames a 16bit word?
4. In page 85, it is also recomended that the gyro range for fast compensation is 125º/s for higher accuracy, instead of 2000º/s. However, if I do it with the 125º/s range selected, can I later on switch to 2000º/s and still mantain the calculated offset compensation?
Thank you in advance,
With best regards,
Miguel Sanches
06-12-2019 02:10 AM
Please refer to the following answers:
But BMX055 have very good gyro performance, so we don't recommend you to do the fast compensation because the intial offset is already qutie small.
06-13-2019 01:03 PM
I just have one further question:
How can I convert the fast compensated accelerometer values into g's?
The fast compensation values of the accelerometer are signed 8-bits integers.
"int8_t compx = readByte(BMX055_ACC_ADDRESS, BMX055_ACC_OFC_OFFSET_X);
int8_t compy = readByte(BMX055_ACC_ADDRESS, BMX055_ACC_OFC_OFFSET_Y);
int8_t compz = readByte(BMX055_ACC_ADDRESS, BMX055_ACC_OFC_OFFSET_Z);"
So, how do I convert 8 bit raw ADC values into g's?
Thanks in advance once again!
