    BMX160 + BSXLite integration
    jminack
    I am developing an application using a BMX160 and the BSXLite library.
    I've read the integration guide was wondering if anybody could clarify the following:
    1) Refering to the Table on page 7 of the guide (screen capture below) about the ODR settings, I am assume this is specifying the required configuration settings for each of the 3 sensors. Is that correct?
    2) I am really unclear about how often I need to feed the library data via the bsx_dostep call. Do I need to feed it at the ODR rate? That is, should I be calling this function at a rate of 100Hz to supply it the accelerometer and gyroscopic sensor?
    3) Table 4 on page 14 shows a list of support data rates (screen capture below). What does Output data rate actually mean in this context?
    4) Section 4 states "...The core & controllers should have sufficient resources (ROM/RAM) for library processing" but doesn't specify what they are. In particular, is there any indication what the stack requirements are?
    5) This has been asked before, but I can't seem to find an answer. For the arrays of values that are passed in via the bsx_init function, what do they mean? Does the BMX160 configuration need to match these values in some way?
    Thanks for any help.
    John
    FAE_CA1
    If you don't have more questions, then please click the "Accept as Solution" button to close this case.
