Hi
After setting my DRDY & TAP INT correctly, according to the solution I figured out on this post, I went back to the MAG settings.
Here is my updated init code:
/*wrapper function to match the signature of bmm150.read */
int8_t bmm150_aux_read(uint8_t id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
/* Discarding the parameter id as it is redundant*/
return bmi160_aux_read(reg_addr, reg_data, len, &bmi);
/*wrapper function to match the signature of bmm150.write */
int8_t bmm150_aux_write(uint8_t id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
printf("bmm_W: reg=%02x, val=%02x\r\n", reg_addr, ((uint8_t *)reg_data)[0] );
/* Discarding the parameter id as it is redundant */
return bmi160_aux_write(reg_addr, reg_data, len, &bmi);
uint8_t aux_addr = BMM150_DATA_X_LSB; /* In BMM150 Mag data starts from register address 0x42 */
// --------------- Init BMX160 ---------------------
bmi.id = BMI160_I2C_ADDR;
bmi.interface = BMI160_I2C_INTF;
bmi.read = I2C_0_readDataBlock;
bmi.write = performDimWrite;
bmi.delay_ms = delay_miliSec;
bmm.dev_id = BMM150_DEFAULT_I2C_ADDRESS;
bmm.intf = BMM150_I2C_INTF;
bmm.read = bmm150_aux_read;
bmm.write = bmm150_aux_write;
bmm.delay_ms = delay_miliSec;
rslt_ = bmi160_init(&bmi);
printf("bmi160_init:%i\r\n", rslt_);
bmi.aux_cfg.aux_sensor_enable = BMI160_ENABLE;
bmi.aux_cfg.aux_i2c_addr = bmm.dev_id;
bmi.aux_cfg.manual_enable = BMI160_ENABLE;
bmi.aux_cfg.aux_rd_burst_len = BMI160_AUX_READ_LEN_3;
rslt_ = bmi160_aux_init(&bmi);
printf("bmi160_aux_init:%i\r\n", rslt_);
rslt_ = bmm150_init(&bmm);
printf("bmm150_init:%i\r\n", rslt_);
//// --------------- Acc & Gryo ---------------------
////printf("Init:AccGyro\r\n");
//// Configure accel and gyro sensors in normal mode
bmi.accel_cfg.odr = BMI160_ACCEL_ODR_50HZ;
bmi.accel_cfg.range = BMI160_ACCEL_RANGE_4G;
bmi.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
bmi.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
bmi.gyro_cfg.odr = BMI160_GYRO_ODR_50HZ;
bmi.gyro_cfg.range = BMI160_GYRO_RANGE_125_DPS;
bmi.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
bmi.gyro_cfg.power = BMI160_GYRO_SUSPEND_MODE;
struct bmi160_int_settg bmi_int_config;
// Configure sensor interrupt (Data Ready)
printf("Init:DataReady\r\n");
bmi_int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 1
bmi_int_config.int_pin_settg.output_en = BMI160_ENABLE;// Enabling interrupt pins to act as output pin
bmi_int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
bmi_int_config.int_pin_settg.output_type = BMI160_ENABLE;// Choosing active High output
bmi_int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;// Choosing level triggered output
bmi_int_config.int_pin_settg.input_en = BMI160_DISABLE;// Disabling interrupt pin to act as input
bmi_int_config.int_pin_settg.latch_dur =BMI160_LATCH_DUR_NONE;// non-latched output
bmi_int_config.int_type = BMI160_ACC_GYRO_DATA_RDY_INT;// Choosing Data Ready interrupt
/* Set the Data Ready interrupt */
rslt_ = bmi160_set_int_config(&bmi_int_config, &bmi); /* sensor is an instance of the structure bmi160_dev */
printf("bmi160_set_int_config:%i\r\n", rslt_);
// Configure sensor interrupt (Tap)
printf("Init:Tap\r\n");
bmi_int_config.int_channel = BMI160_INT_CHANNEL_2;// Interrupt channel/pin 2
bmi_int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE;// non-latched output
/* Select the Interrupt type: Tap */
bmi_int_config.int_type = BMI160_ACC_SINGLE_TAP_INT;// Choosing Step Detector interrupt
/* Select the Step Detector interrupt parameters, Kindly use the recommended settings for step detector */
bmi_int_config.int_type_cfg.acc_tap_int.tap_en = BMI160_ENABLE;// 1-enable, 0-disable the detector
bmi_int_config.int_type_cfg.acc_tap_int.tap_data_src=BMI160_DISABLE; // use pre-filter
bmi_int_config.int_type_cfg.acc_tap_int.tap_dur = 1; // not applicable to single tap
bmi_int_config.int_type_cfg.acc_tap_int.tap_quiet = BMI160_DISABLE; // 30/20ms
bmi_int_config.int_type_cfg.acc_tap_int.tap_shock = BMI160_DISABLE; // 50/75ms
bmi_int_config.int_type_cfg.acc_tap_int.tap_thr = 10; // 0-31: 125mg/2 = 62.5mg per bit (4g range)
/* Set the Tap Detector interrupt */
rslt_ = bmi160_set_sens_conf(&bmi);
printf("bmi160_set_sens_conf:%i\r\n", rslt_);
/* Set the Power mode */
rslt_ = bmi160_set_power_mode(&bmi);
printf("bmi160_set_power_mode:%i\r\n", rslt_);
// --------------- Mag ---------------------
//printf("Init:Mag\r\n");
// from <a href="https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BMX160-magnetometer-problem/td-p/7628/page/2" target="_blank">https://community.bosch-sensortec.com/t5/MEMS-sensors-forum/BMX160-magnetometer-problem/td-p/7628/page/2</a>
bmm.settings.pwr_mode = BMM150_NORMAL_MODE;
rslt_ = bmm150_set_op_mode(&bmm);
printf("bmm150_set_op_mode:%i\r\n", rslt_);
bmm.settings.preset_mode = BMM150_PRESETMODE_ENHANCED;
rslt_ = bmm150_set_presetmode(&bmm);
printf("bmm150_set_presetmode:%i\r\n", rslt_);
bmi.aux_cfg.aux_odr = BMI160_AUX_ODR_50HZ;
rslt_ = bmi160_config_aux_mode(&bmi);
printf("bmi160_config_aux_mode:%i\r\n", rslt_);
bmm.settings.pwr_mode = BMM150_FORCED_MODE;
// set aux/mag to auto mode
rslt_ = bmi160_set_aux_auto_mode(&aux_addr, &bmi);
printf("bmi160_set_aux_auto_mode:%i\r\n", rslt_);
I have changed my read code to poll the mag_drdy bit to check for new data. This bit is only set once right after init completes.
In an effort to see what is begin written to the internal BMM150 (contained in the BMX160), I put a printf at the bmm150_aux_write function.
Here is the full output from the above init code:
bmi160_init:0
bmi160_aux_init:0
bmm_W: reg=4b, val=01
bmm150_init:0
Init:DataReady
bmi160_set_int_config:0
Init:Tap
bmi160_set_sens_conf:0
bmi160_set_power_mode:0
bmm_W: reg=4c, val=00
bmm150_set_op_mode:0
bmm_W: reg=51, val=07
bmm_W: reg=52, val=1a
bmm150_set_presetmode:0
bmi160_config_aux_mode:0
bmm_W: reg=4c, val=02
bmi160_set_aux_auto_mode:0
And here is the declutted version only showing the registers being written to the BMM150:
I've relooked at the example on the BMX160 GitHub page, but I'm still not getting measurement data from the BMX160's MAG.
I'm getting desparate at all the examples I've tried are not giving any results.
Has anyone been able to get the BMX160's MAG working at the same data rate as the ACC? I'll even accept a slower output rate just to verify my setup.
Could you please post example code?
Hi rdehart,
this might be a dumb suggestion, but did you check the hardware connections? Are VDD and VDDIO connected to your power source?
Kind regards,
Marko Njirjak
Hi Marko
Yes. I confirmed both VDD & VDDIO are connected to the voltage source.
I also scoped the SCLA line and the clock is rising fast enough for 100kHz and not ringing.
It seems the hardware is fine, since the ACC data is coming through.
Thanks for the thought
Just to check, I am going to try 2 things (not sure if these would affect MAG data):
