    BMX160 Magnetometer
    Highlighted
    BMX160 Magnetometer
    Hi everyone, I have purchased the BMX160 shuttle board. Base on this API I've managed to receive some data with the time stamp. However, I have some questions:
    1. How can I ensure that I am receiving the correct values from the magnetometer? I am receiving a constant value of 2047 on the z-axis, is this normal?
    2. I am using the accel.sensortime to get the time stamp but I am not sure what is its returning type, is this microseconds? I am calling read_sensor_data() every one second.
    This is the function I am calling to receive data.
    struct bmi160_dev sensor; //For Accel and Gyro
    struct bmm150_dev bmm150; //For Mag
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    static void read_sensor_data() {
      m_xfer_done = false;
      bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &sensor);
      bmi160_read_aux_data_auto_mode(mag_data, &sensor);
      bmm150_aux_mag_data(mag_data, &bmm150);
      NRF_LOG_INFO("Time:%d , AccelX:%d , AccelY:%d , AccelZ:%d",accel.sensortime, accel.x, accel.y, accel.z);
      NRF_LOG_INFO("GyroX:%d , GyroY:%d , GyroZ:%d", gyro.x, gyro.y, gyro.z);
      NRF_LOG_INFO("MagX:%d , MagY:%d , MagZ:%d", bmm150.data.x, bmm150.data.y, bmm150.data.z);
    4 REPLIES 4
    Highlighted
    Re: BMX160 Magnetometer
    Hi Niko,
    • How can I ensure that I am receiving the correct values from the magnetometer? I am receiving a constant value of 2047 on the z-axis, is this normal?
    ----No. it's abnormal.  It seems signed or unsigned define issue in your code or driver.
    • I am using the accel.sensortime to get the time stamp but I am not sure what is its returning type, is this microseconds? I am calling read_sensor_data() every one second.
    ----Sensortime is a 24-bit counter in register 0x18~0x1A. The sensortime increments with 39us. accuracy is same as the ODR.
    Highlighted
    Hi Shellywang
    Thank you for your answer
    Could you please explain me what you mean by signed or unsigned define issue? Sorry, I am new to this and still learning 🙂
    Highlighted
    Anyone?
    Highlighted
    Please use the data structure in our API and follow the X/Y/Z axis data processing function in API , be care for the positive/negative and overflow.
