Hi everyone,
At the moment I am working on power optimizing BMX160. When my firmware starts I initialize the sensor by setting
Accel = Normal Mode
Gyro = Normal Mode
Mag = Forced Mode
This is my BMI160() function
void BMI160_init(void) {
uint8_t data = 0;
sensor.id = BMI160_I2C_ADDR; //0x68
sensor.interface = BMI160_I2C_INTF; //0x00
sensor.read = Acc_i2c_Read;
sensor.write = Acc_i2c_Write;
sensor.delay_ms = Acc_delay_ms;
bmm150.dev_id = BMM150_DEFAULT_I2C_ADDRESS;
bmm150.intf = BMM150_I2C_INTF;
bmm150.read = bmm150_aux_read;
bmm150.write = bmm150_aux_write;
bmm150.delay_ms = Acc_delay_ms;
rslt = bmi160_init(&sensor);
APP_ERROR_CHECK(rslt);
sensor.aux_cfg.aux_sensor_enable = 1; // auxiliary sensor enable
sensor.aux_cfg.aux_i2c_addr = BMI160_AUX_BMM150_I2C_ADDR; // auxiliary sensor address
sensor.aux_cfg.manual_enable = 1; // setup mode enable
sensor.aux_cfg.aux_rd_burst_len = 2; // burst read of 2 byte
rslt = bmi160_aux_init(&sensor);
rslt = bmm150_init(&bmm150);
if (rslt == BMI160_OK) {
//NRF_LOG_INFO("BMI160 Initialized...");
} else {
//NRF_LOG_INFO("BMI160 not Initialized...");
NRF_LOG_FLUSH();
sensor.accel_cfg.odr = BMI160_ACCEL_ODR_400HZ; // na - Accel Output Data Rate - 400Hz is the min acceptable ODR in order to measure at 100Hz. See table 13 pg21
sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G; // na - Range of accel measurements
sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4; // Number of averaging cycling. The higher the AVG the lower the noise but the higher the current consumption (see pg18 Table 9). Important for Low Power Mode
sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE; // na - Set the power mode (see pg15 Table 7,pg16 Table 8 ,pg18 Table 9)
sensor.gyro_cfg.odr = BMI160_GYRO_ODR_400HZ; // na - Output Data Rate - 400Hz is the min acceptable ODR in order to measure at 100Hz. See table 15 pg23
sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS; // na - Range of gyro measurements
sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE; // The gyro bandwidth coefficient defines the 3dB cutoff frequency for the low pass filter for the sensor data (see pg22 2.4.2)
sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE; // na - Set the power mode (see pg15 Table 7,pg16 Table 8 ,pg18 Table 9)
rslt = bmi160_set_sens_conf(&sensor); // configure the ODR, range, power mode and bandwidth of sensor
nrf_delay_ms(150); // na - see pg 90 of BMX160 datasheet
/* Configure the magnetometer. The regular preset supports up to 100Hz and the Low Power Preset up to 200Hz in Forced mode (see pg19 Table 11) */
bmm150.settings.preset_mode = BMM150_PRESETMODE_LOWPOWER; // na - The higher the preset the lower the noise but the higher the current consumption (see pg19 Table 11)
rslt = bmm150_set_presetmode(&bmm150);
bmm150.settings.pwr_mode = BMM150_FORCED_MODE; // na - see datasheet pg16 Magnetometer power mode section
rslt = bmm150_set_op_mode(&bmm150);
// bmm150_get_regs(BMM150_OP_MODE_ADDR, &data, 1, &bmm150); // na - Read the BMM150_OP_MODE_ADDR (0x4C) register
// NRF_LOG_INFO("BMM150_OP_MODE_ADDR (0x4C) : %d", data);
sensor.aux_cfg.aux_odr = BMI160_AUX_ODR_100HZ;
bmi160_config_aux_mode(&sensor);
bmi160_set_aux_auto_mode(&aux_addr, &sensor);
//NRF_LOG_INFO("sensor Configured...");
} else {
//NRF_LOG_INFO("sensor not Configured...");
rslt = bmi160_get_regs(BMI160_PMU_STATUS_ADDR, &data, 1, &sensor);
NRF_LOG_INFO("BMI160_PMU_STATUS_ADDR - STAND BY STATE: %d", rslt);
After setting the power modes and applying the nesessary delay according to page 90 of the datasheet, I am still reading 0s from PMU_STATUS (0x03) register. This is strange because I can read normally the values from all of the 9 axis of the sensor..
Any advice?
Thanks in advance
Nick
I have replied to you in another thread. Please use a USB logic analyzer to capture the I2C waveform for your function and send it to us. We will check what went wrong.
