    BMX160 Power Mode - Transitions
    Nikosant03
    Long-established Member
    Hi everyone,
    I have a question regarding the switching in Power Modes. What can I understand is that there are two ways to change power mode:
    EITHER
    sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
    sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
    rslt = bmi160_set_sens_conf(&sensor);
    OR
    rslt = bmi160_set_power_mode(&sensor);
    Which function should I use in order to change properly power mode?  Should I should both functions? Should I use both functions but in a particular order?
    Please advice
    Thanks in advance
    Nick
    fish
    From API code as bellow, two function are different. So you could follow example code to make configuration.
     * @brief This API configures the power mode, range and bandwidth
     * of sensor.
    int8_t bmi160_set_sens_conf(struct bmi160_dev *dev)
        int8_t rslt = BMI160_OK;
        /* Null-pointer check */
        if ((dev == NULL) || (dev->delay_ms == NULL))
            rslt = BMI160_E_NULL_PTR;
        else
            rslt = set_accel_conf(dev);
            if (rslt == BMI160_OK)
                rslt = set_gyro_conf(dev);
                    /* write power mode for accel and gyro */
                    rslt = bmi160_set_power_mode(dev);
                        rslt = check_invalid_settg(dev);
        return rslt;
     * @brief This API sets the power mode of the sensor.
    int8_t bmi160_set_power_mode(struct bmi160_dev *dev)
        int8_t rslt = 0;
        else
            rslt = set_accel_pwr(dev);
                rslt = set_gyro_pwr(dev);
        return rslt;
    Nikosant03
    Thank you for your reply fish
    Actually the bmi160_set_sens_conf() includes the bmi160_set_power_mode()..
    So I could use either the bmi160_set_sens_conf() or the bmi160_set_power_mode() to switch power mode right? It is identical isn't it?
    Vincent
    Yes, they are identical if you put correct power mode value into configure data group already.
