    BMX160 RETURNS 0
    Highlighted
    Senior Member
    BMX160 RETURNS 0
    Hi everyone,
    I am trying to read data from the BMX160 sensor. I used the driver for the BMI160 sensor as I read that it is compatible.
    I changed the CHIP_ID to 0xD8 and also I scanned the I2C address (which is 0x68). However, the return values for accel and gyro are zero.
    Do I miss something?
    This is the code
    #include <stdio.h>
    #include "boards.h"
    #include "app_util_platform.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "nrf_log_default_backends.h"
    #include "bmi160.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    struct bmi160_dev sensor;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    int8_t rslt = BMI160_OK;
    /*TWI initialization*/
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        APP_ERROR_CHECK(err_code);
        if (NRF_SUCCESS == err_code)
    		nrf_drv_twi_enable(&m_twi);
    		NRF_LOG_INFO("TWI init success...");
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
        //  NRF_LOG_INFO("WRITE: dev_id: %x reg_addr: %x reg_data: %x len: %i\n", dev_id, reg_addr, *reg_data, len);
    	int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, reg_data, len + 1, false);
    	APP_ERROR_CHECK(rslt);
            return rslt;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
           // NRF_LOG_INFO("READ: dev_id: %x reg_addr: %x len: %i\n", dev_id, reg_addr, len);
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, false);
    	if (rslt == 0)
    		rslt = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
            NRF_LOG_INFO("READ: %x",*reg_data);
    	return rslt;
    void Acc_delay_ms(uint32_t period)
    /*if (period==NULL){
    period = 1;
    }// delay time*/
      nrf_delay_ms( period ) ;
    void BMI160_init (void)
        sensor.id = BMI160_I2C_ADDR;         //0x68
        sensor.interface = BMI160_I2C_INTF;  //0x00
        sensor.read = &Acc_i2c_Read;
        sensor.write = &Acc_i2c_Write;
        sensor.delay_ms = &Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("BMI160 Initialized...");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized...");
        }NRF_LOG_FLUSH();
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_100HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        rslt = bmi160_set_sens_conf(&sensor);
        NRF_LOG_INFO("sensor Configured...");
        } else {
        NRF_LOG_INFO("sensor not Configured...");
        }NRF_LOG_FLUSH();
    static void read_sensor_data()
          bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL), &accel, &gyro, &sensor);
          NRF_LOG_INFO("DataX:%d", accel.x);
          NRF_LOG_INFO("DataY:%d", accel.y);
          NRF_LOG_INFO("DataZ:%d", accel.z);
          NRF_LOG_INFO("GyroX:%d", gyro.x);
          NRF_LOG_INFO("GyroY:%d", gyro.y);
          NRF_LOG_INFO("GyroZ:%d", gyro.z);
    int main(void)
        bsp_board_init(BSP_INIT_LEDS);
        APP_ERROR_CHECK(NRF_LOG_INIT(NULL));
        NRF_LOG_DEFAULT_BACKENDS_INIT();
        NRF_LOG_INFO("BMI160 get started.\n");
        NRF_LOG_FLUSH();
        Acc_delay_ms(100);
        twi_init();
        Acc_delay_ms(50);
        BMI160_init();
        Acc_delay_ms(100);
        while(true)
          nrf_delay_ms( 1000 ) ;
          /* do
                __WFE();
            }while (m_xfer_done == false);*/
            read_sensor_data();
            NRF_LOG_FLUSH();
    Highlighted
    Senior Member
    Re: BMX160 RETURNS 0
    I finally figured out the issue..
    Highlighted
    Can you share what the fix was? I'm having a similar issue. Thanks
    Here is my code:
    /* imu setup */
        sensor.read = &bmx160_i2c_read;            // Function pointer to SPI read
        sensor.write = &bmx160_i2c_write;  // Function pointer to SPI write
        sensor.delay_ms = &delay_ms;               // Function pointer to delay(ms) function
        rslt = BMI160_OK;
        /* Select the Output data rate, range of accelerometer sensor */
        /* Select the power mode of accelerometer sensor */
        /* Select the Output data rate, range of Gyroscope sensor */
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_3200HZ;
        /* Select the power mode of Gyroscope sensor */
        rslt = BMI160_OK;
        /* To read both Accel and Gyro data along with time*/
        rslt = bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &sensor);
    I'm able to read the sensor time fine, but the accel and gyro values are all reading 0.
    Highlighted
    Nevermind, solved the issue. I had a problem with my i2c write function which wasn't including the reg addr. Its working now.
