since the temperature is needed during magnetometer compensation. Is there a way to get the data into the FIFO? Or do I have to read out the temperature manually?
Kind regards,
Constantin
Okay but I cannot find something in the Datasheet there I can only configure
Could you tell me the page where I have to look. Because I've searched it already in detail. Furthermore, the link you mentioned does not even know the word temperature nor the source code.
So could you tell me where I should find it?
Kind regards,
Constantin
Hello cwi,
I deleted my previous reply, sorry for confusing.
Temperature is not possible for FIFO. Only gyro, accelerometer, mag are possible for FIFO data frame.
https://www.bosch-sensortec.com/media/boschsensortec/downloads/datasheets/bst-bmx160-ds0001.pdf
You can check it P29. in datasheet.
