    BMX160 Step Detection
    Nikosant03
    Long-established Member
    Hi everyone,
    I want to configure BMX160 for step detection for human beings. The sensor will be placed inside the insole.
    Could you please help me to configure the parameters for min_steptime and min_threshold in order to achieve a robust step detection? I cannot find any information for those parameters into the datasheet.. The only info I can find is regarding the working mode (Normal, Sensitive, Robust) and there is no information regarding the bits on registers 0x7A - 0x7B (see 2.11.37 pg 88)
    This is my configuration so far
    void stepDetector_set(struct bmi160_dev *dev) {
      int8_t rslt = 0;
      int_config.int_channel = BMI160_INT_CHANNEL_1; // Interrupt channel/pin 1
      int_config.int_type = BMI160_STEP_DETECT_INT;
      int_config.int_pin_settg.output_en = BMI160_ENABLE;         // na - Enabling interrupt pins to act as output pin
      int_config.int_pin_settg.output_mode = BMI160_DISABLE;      // na - Choosing push-pull mode for interrupt pin
      int_config.int_pin_settg.output_type = BMI160_ENABLE;       // na - Choosing active High output
      int_config.int_pin_settg.edge_ctrl = BMI160_ENABLE;         // na - Choosing edge triggered output
      int_config.int_pin_settg.input_en = BMI160_DISABLE;         // na - Disabling interrupt pin to act as input
      int_config.int_pin_settg.latch_dur = BMI160_LATCH_DUR_NONE; // na - non-latched output
      int_config.int_type_cfg.acc_step_detect_int.min_threshold =                                 // ??????
      int_config.int_type_cfg.acc_step_detect_int.step_detector_en = BMI160_ENABLE;           // na - 1-enable, 0-disable the step detector
      int_config.int_type_cfg.acc_step_detect_int.step_detector_mode = BMI160_STEP_DETECT_NORMAL;  // na - Set Normal Mode
      int_config.int_type_cfg.acc_step_detect_int.step_min_buf =                                  // ??????
      int_config.int_type_cfg.acc_step_detect_int.steptime_min =                                 // ??????
      /* Set the Step Detector interrupt */
      rslt = bmi160_set_int_config(&int_config, dev); /* sensor is an instance of the structure bmi160_dev */
      if (rslt != BMI160_OK) {
        //printf("BMI160 Step Detector interrupt configuration failure!\n");
      } else {
        //printf("BMI160 Step Detector interrupt configuration done!\n");
    Thanks in advance
    Nick
    13 REPLIES 13
    Hello Nikosant03,
    Which mode did you use? If it is sensitive for you, you could choose normal mode robust mode for your application.
    Nikosant03
    Hi BSTRobin
    I tried all the modes (sensitive/normal/robust) but I have the same problem. When I jump an interrupt is generated... Actually this makes sense since the step detection interrupt is based on the accelerometer. I suppose that while jumping I exceed the predefined accel's threshold and that's why the interrupt is generated. How could I work around this issue since I do not want to interrupt while jumping (it is not a step 😀)?
    Thanks for your assistance so far!!
    Nick
    Hello Nick,
    Could I know  your application?
    For your jumping test, it needed to record detailed test procedure according your application, capture more than one hundred steps of data(X, Y, Z axis LSB data) to analyse it.
    Nikosant03
    Hi BSTRobin,
    I will use the BMX160 inside the insole of a shoe. When steps are detected (meaning that the user has wear the shoe) then the interrupt signal will wake up the MCU from its Low Power state. This is the reason I want to filter out the jumps as well as events that are not related with steps, because I do not want the MCU to wake up from events irrelavant with steps.
    Do you have any code, that is capable of detecting steps with higher accuracy?
    Nick
    Hello Nick,
    To prevent false triggering, BMI160 step counter has a buffer mechanism. For example, if 6 steps was buffered, step counter value will be read out with the 7th step.
