    BMX160 magnetometer problem
    Re: BMX160 magnetometer problem
    OK, I figured it out. Unfortunately I forgot to connect VDDIO pin to the power supply. After I did so and tried the sample code, everything worked like a charm. Thank you very much for your assistance, I really appreciate it.
    For anyone else experiencing the same problem, please make sure you connect VDDIO to power supply. The code that I used can be found here. I modified it a bit and tested everything by reading all three sensors. Here's the code that I used:
    #include "bmi160.h"
    #include "bmm150.h"
    struct bmi160_dev bmi;
    struct bmm150_dev bmm;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    int8_t bmm150_aux_read(uint8_t id, uint8_t reg_addr, uint8_t *aux_data, uint16_t len);
    int8_t bmm150_aux_write(uint8_t id, uint8_t reg_addr, uint8_t *aux_data, uint16_t len);
    int main(void)
        bmi.id = 0;
        bmi.interface = BMI160_SPI_INTF;
        bmi.read = spi_read_transfer;
        bmi.write = spi_write_transfer;
        bmi.delay_ms = delay;
        bmm.dev_id = BMM150_DEFAULT_I2C_ADDRESS;
        bmm.intf = BMM150_I2C_INTF;
        bmm.read = bmm150_aux_read;
        bmm.write = bmm150_aux_write;
        bmm.delay_ms = delay;
        bmi160_init(&bmi);
        bmi.aux_cfg.aux_i2c_addr = bmm.dev_id;
        bmi.aux_cfg.manual_enable = BMI160_ENABLE;
        bmi.aux_cfg.aux_rd_burst_len = BMI160_AUX_READ_LEN_3;
        bmi160_aux_init(&bmi);
        bmm150_init(&bmm);
        bmi.accel_cfg.odr = BMI160_ACCEL_ODR_100HZ;
        bmi.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        bmi.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        bmi.gyro_cfg.odr = BMI160_GYRO_ODR_100HZ;
        bmi.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        bmi.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        bmi.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        bmi160_set_sens_conf(&bmi);
        bmm.settings.preset_mode = BMM150_PRESETMODE_REGULAR;
        bmm150_set_presetmode(&bmm);
        bmm.settings.pwr_mode = BMM150_FORCED_MODE;
        bmm150_set_op_mode(&bmm);
    	uint8_t aux_addr = 0x42;
    	uint8_t mag_data[8] = {0};
    	uint8_t index;
    	bmi.aux_cfg.aux_odr = 8;
    	bmi160_config_aux_mode(&bmi);
    	bmi160_set_aux_auto_mode(&aux_addr, &bmi);
        while(1) {
            bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL), &accel, &gyro, &bmi);
        	bmi160_read_aux_data_auto_mode(mag_data, &bmi);
        	bmm150_aux_mag_data(mag_data, &bmm);
            printf("****************\n");
            printf("ACC X: %d, Y: %d, Z: %d\n", accel.x, accel.y, accel.z);
            printf("GYRO X: %d, Y: %d, Z: %d\n", gyro.x, gyro.y, gyro.z);
        	printf("MAG X : %d Y : %d Z : %d\n", bmm.data.x, bmm.data.y, bmm.data.z);
            printf("################\n");
    int8_t bmm150_aux_read(uint8_t id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
        (void) id;
        return bmi160_aux_read(reg_addr, reg_data, len, &bmi);
    int8_t bmm150_aux_write(uint8_t id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len) {
        (void) id;
        return bmi160_aux_write(reg_addr, reg_data, len, &bmi);
    where spi_read_transfer, spi_write_transfer and delay represent master-chip-specific functions for spi transfers and delay.
    The sample data that I got:
    ACC X: -16140, Y: 27, Z: -551
    GYRO X: 7, Y: 3, Z: -5
    MAG X : 37 Y : -12 Z : 6
    ACC X: -16171, Y: -18, Z: -516
    GYRO X: 8, Y: 2, Z: -5
    MAG X : 36 Y : -12 Z : 7
    ACC X: -16132, Y: -13, Z: -550
    GYRO X: 8, Y: 3, Z: -5
    MAG X : 37 Y : -12 Z : 8
    Once again, thank you for your help!
    Kind regards,
    Marko Njirjak
    Great !
    Glad your issue is fixed, and thanks for posting your solution here! Robot Happy
    Hi, could you show your implementation of user_spi_read/write and if possible user_i2c_read and write?
