    BMX160 : no FIFO watermark interrupt + fifo streaming question
    André
    I am using the code below to generate fifo watermark interrupts but I don't see any watermark interrupts generated. What am I doing wrong?
    (Sorry for the bad make up but I dont see an option to add a code )
    int8_t Open_BMI160_FIFO(struct bmi160_dev *dev)
    int8_t rslt = BMI160_OK;
    fifo_frame.data = fifo_buff;
    fifo_frame.length = 1024;
    dev->fifo = &fifo_frame;
    /* Clear FIFO configuration register */
    rslt = bmi160_set_fifo_config(BMI160_FIFO_CONFIG_1_MASK, BMI160_DISABLE, dev);
    if (rslt != BMI160_OK)
    PDEBUG("Clear FIFO configuration register error, error code: %d\r\n", rslt);
    return rslt;
    rslt = bmi160_set_fifo_wm(43, dev);//7*50=350 bytes, water mark value was word unit, cann't be greater than 255, 87*4=348
    if(rslt != BMI160_OK)
    PDEBUG("bmi160_set_fifo_wm error, error code: %d\r\n", rslt);
    // BMI160_FIFO_A_ENABLE enable fifo for accelerometer only
    rslt = bmi160_set_fifo_config(/*BMI160_FIFO_A_ENABLE |BMI160_FIFO_TAG_INT1 */
    BMI160_FIFO_ACCEL|BMI160_FIFO_HEADER, BMI160_ENABLE, dev);
    PDEBUG("bmi160_set_fifo_config error, error code: %d\r\n", rslt);
    /* Flush FIFO */
    rslt = bmi160_set_fifo_flush(dev);
    PDEBUG("Flush FIFO error, error code: %d\r\n", rslt);
    return rslt;
    int_config.int_channel = BMI160_INT_CHANNEL_1;// Interrupt channel/pin 2
    int_config.int_type = BMI160_ACC_GYRO_FIFO_WATERMARK_INT;// Choosing interrupt
    int_config.int_pin_settg.output_mode = BMI160_DISABLE;// Choosing push-pull mode for interrupt pin
    int_config.int_pin_settg.output_type = BMI160_DISABLE;// Choosing active high output
    int_config.int_pin_settg.edge_ctrl = BMI160_DISABLE;// Choosing edge triggered output
    int_config.fifo_wtm_int_en = BMI160_ENABLE;//Enable FIFO watermark interrupt
    /* Set the FIFO watermark interrupt */
    bmi160_set_int_config(&int_config, dev);
    return rslt;
    2 REPLIES 2
    Hi André,
    1.What is ODR you used?
    2.How long do you want to get watermark interrupt?
    3.Has the interrupt pin on the host side was connected to INT1 and been initialized?
    André
    I fixed it, cause was a to low watermark at an ODR of 1600Hz.  😕
