Is there available some sample 9-axis output data, for example stored in a 9-channel wav file or other format ?
We are working on robotics failure prediction for industrial customers using the BMX160 in their products
Hi jbrower,
The attachment is an example of reading 9-axis data from BMX160, which calls the BMI160 and BMM150 sensor APIs.
BMI160 sensor API: https://github.com/BoschSensortec/BMI160_driver
BMM150 sensor API: https://github.com/BoschSensortec/BMM150-Sensor-API
Hi BSTRobin-
I'm looking for sample output data, not APIs. Is there some output data used for test purposes, possibly in XML, wav, or binary format ? If so that would work. Thanks.
-Jeff
Hi jbrower,
If you have BMX160 shuttle board and applicaton board, you cound run them under development desktop software, and record 9-axis output data.
