    BMX160 read and write function
    st105883
    Hi all,
    as part of my masters thesis I need to connect the Bosch Bmx160 Shuttle board to an Infineon Aurix Triboard MC so I can read accel and gyro data. However, I have a few questions about the initialization of the sensor.
    1. The first question is if i have to set the sensor Id to "0" or to "BMI160_CHIP_ID" ( which is 0xD8 in my case)?
    2. What do I have to write in the Read and Write Function? Do I have to write the two functions myself or is this the interface with my MC that I just have to put in? If I have to write the function myself, what does it look like?
    Please sorry if the questions sound too stupid, but I am quite new with the programming language as well as with sensors and MCs. I am just trying to understand how all this works.🙈
    Thank you and best regards
    "int8_t user_spi_read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len);"
     "int8_t user_spi_write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len);"
    sensor.id = 0;
    sensor.interface = BMI160_SPI_INTF;
    sensor.read = user_spi_read;
    sensor.write = user_spi_write;
    sensor.delay_ms = user_delay_ms;
    Minhwan
    Hello st105883,
    First of all, my comment is based on our official code.
    - If you are using SPI and only one slave, it is okay to put 0 value, but I'd like to recommend to put the GPIO value for BMX160 chip select pin in Infineon device.
    Simply say, you have to write your own SPI write or read function in bmi160_read_spi and bmi160_write_spi for communication between MCU and BMX160. I attached an example code.
