    BNO055 32KHz clock externally supplied?
    3pa11e
    Hello together,
    can the BNO055 be supplied with an externally generated 32K clock signal? If yes, (presumably at pin 27, XIN) how should that signal look (form, min/max amplitude, min/max duty cycle)?
    2 REPLIES 2
    o_o
    Contributor
    BNO055 does not offer logic-level clock input. The external clock must be a crystal.
    BMF055 on the other hand is freely programmable, and the internal SAMD20J18RevB does support logic level clocking.
    THANKS for the quick answer!
