06-16-2020 06:47 PM
Hi all,
Is there a possibility to measure the direction of movement in sensor-body-coordinates with the BNO055?
Generally, the approach would be to integrate linear acceleration over time to obtain the velocity in each axis and keep track of velocity to obtain a vector of the actual movement of the sensor. However, in the datasheet of the BNO055 sensor it says integrating lineare acceleration is not a good idea:
Note: The linear acceleration signal typically cannot be integrated to recover velocity, or
double-integrated to recover position. The error typically becomes larger than the signal within
less than 1 second if other sensor sources are not used to compensate this integration error.
Is it possible to perform such a task with the BNO055? The value of the velocities is not important only the direction of movement.
Thanks for your help.
06-18-2020 09:09 AM
This was my initial idea to perform this task, but after reading through the data sheet I was concerned about the note of not integrating linear acceleration.
Thanks very much for clarification.
