We've found that there are some reset issues on the BNO055 when not using an external clock so we are attempting to add one.
However, we want to make sure we get the right clock with the right specs and would like some input from Bosch if possible.
We are looking at the ABS07-32.768KHZ-T clock since it's cheap and has good stability (20 ppm).
- 12.5pF load capacitance
- 70 kOhms Equivalent Series Resistance (ESR)
Is this clock appr0priate for the BNO055?
Or, what would really help is to know what clock PN Bosch is using for their BNO055 shuttle board.
Thank you
