10-12-2020 10:19 AM
in my design, the BNO055 INT pin is shared with other I2C slave INT pins.
Is there a way to re-configure the BNO055 INT pin as active low?
From the datasheet:
INT is configured as interrupt pinfor signaling aninterrupt to the host. The interrupt trigger is configured as raising edge and is latched on to the INT pin. Once an interrupt occurs, the INT pin is set to high and will remain high until it is reset by host.
10-13-2020 12:50 AM
The BNO055 INT pin behavior is hard coded in the FW of BNO055.
There is no way just change it from registet level.
