    BNO055 / Minimum I2C communication interval ?
    I would like to know miminum I2C communication interval  between  transmissions.
    I mean, BNO055 supports clock stretching.  So then, required time of one transmission may
    exnpanded, right?
    How could I determine the minimum transmission interval?
    Thank you and best regards.
    Takuto Yoshioka
    Tags (1)
    8 REPLIES 8
    Re: BNO055 / Minimum I2C communication interval ?
    All I2C required timing are already included in the BNO055 datasheet.
    As additional information,  you can put around 2 - 3 us interval between I2C command under  normal power mode.
    For reading sensor data, just polling as defined ODR should be OK or you can use interrupt based reading.
    Vincent -san,
    Sorry for late to reply.
    Thank you very much for your advice.
    Best reagards,
    Takuto Yoshioka
     I am trying to connect bno055 shuttle board (with its application board) with my Raspberry pi 3 Model B via i2c which is giving me clock stretching problem. Is there any way we can solve this? If yes then How?
    Hi Ridah,
    As far as I know, the processor from Broadcom that is used on the Raspberry Pi has a bug in the I2C master and doesn't support clock stretching as per the standard specification. It is only within spec for speeds of 3.4MHz which the BNO055 doesn't support.
    kgoveas
