08-24-2020 10:51 AM - edited 08-24-2020 02:14 PM
I am using BNO055 for reading the yaw,pitch and roll values. How do i read this orientation using UART protocol. I went through the datasheet,seems like we need to send a register read command mentioning the register address and length of data. I am trying the same but not able to read data. Do i need to set the protocol selection to UART first? Is there any precondition to be followed for reading values from register. Am i missing something here.
Is there any API or LabVIEW drivers available?
Please guide me through, any quick help would be highly appreciated.
09-11-2020 10:08 AM
Thanks Vincent for letting me know.
One more thing i would like to know is how to reset calibration profile ? There is a reset system button to remove the effect of previous calibration data in the new calibration routine available in DD2.0 Bosch software.
What all needs to be done to reset the sensor calibration?
I tried to write 00 value to all 3 sensor offset,made sure it is written properly but still when i stream again the calibration is shown to be same as previous,all sensor are showing fully calibrated. Do we need to clear sensor radius registers also?
Please guide me on how the calibration profile can be resetted just like when we do reset system in DD2.0
09-12-2020 12:00 AM
No, you can not just reset the calibration parameters.
You need to reset the whole system.
The calibration module is running in sensor automatically and can't be disable.
So just write 0 to the calibration parameters will not cause the result of calibration reset.
09-15-2020 08:58 AM
Which function needs to be invoked in generic API's for system reset? Please guide.
09-16-2020 12:18 AM
If you use BNO055 API, you can directly call bno055_set_sys_rst.
Since you are using general API, you can try to write bit 5 of register address 0x3F on page 0 (RST_SYS) directly
09-25-2020 03:07 PM
Thanks Vincent for your timely help. Calibration reset worked just fine.
